Results 1 to 14 of 14
    Nov 2011
    Romania
    Default t5 edc16u1 dtc remove please
    0281010733flashedc16u1.zip can someoane help me remove dtc p0235 , the car runs fine , i have changed the turbo , map n 75 vaalve, i have check hoses and vacums.etc but stil the same problem after 3500rpm
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    Check this out,No CS:
    Please dear members push the button if my work was helpfull!
    And reputation button(star)
  3. The Following User Says Thank You to drewdom For This Useful Post:
    Tzepy (8th June, 2016)
    Nov 2011
    Romania
    thanks, y wil try and report
    Nov 2011
    Romania
    the dtc does not aper anymore but the car stil runs in limp mode at 3500rpm and works again only after swiching off and on again
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    What you have there actually - over or under boost?
  7. The Following User Says Thank You to bobolin4o For This Useful Post:
    Tzepy (10th June, 2016)
  8. #6
    Nov 2011
    Romania
    underboost, control limit not reached, but the car run and at mesuring blocks the diference betwen actual and desire is very smal
  9. #7
    Nov 2011
    Romania
    but after dtc apears the car runs in limp mode until the ignition is swiched off and on again , whit drewdom file the dtc dont apear but stil runs in limp mode
  10. #8
    bobolin4o's Avatar
    Very small, but exist... How much is exactly?
    And what shows the MAF... maybe there is some hole...
    File is ori or? I can't find appropriate file to compare...
  11. The Following User Says Thank You to bobolin4o For This Useful Post:
  12. #9
    Nov 2011
    Romania
    first file thet ii posted is ori , 100mb , the dtc aper only at 3500 rpm , i search for holes ther is none , vacums , map, n75 , turbo , etc but is stil the same, limp mode at that dtc can de erase?
  13. #10
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Limp mode from DTC dont exist ! also small differences are 20mb not 100mb or more ! the maxim tolerance value for boost are +/- 50mb !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  14. The Following 2 Users Say Thank You to mihaiservice For This Useful Post:
    CustomCars (9th June, 2016), Tzepy (10th June, 2016)
  15. #11
    EUROPE
    Quote Originally Posted by Tzepy View Post
    Until 3500 rpm the car is fine?has power?
  16. #12
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    I can disable limp for this problem, but that's no any solution ! Limp mode is for protect engine, if we allow more difference in this condition that's will not help this car driving.
    Sorry but i don't trust at maked work.
    Log for us this car dynamic at 3 gear from 1500rpm
    Replace not check ! -> N75
    get turbo from car and check variable geometry working if any problem clean.
    Next possible problem driver in ecu.
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
  17. The Following 3 Users Say Thank You to CustomCars For This Useful Post:
    bobolin4o (9th June, 2016), kospoz (9th June, 2016), Tzepy (10th June, 2016)
  18. #13
    Nov 2011
    Romania
    the car has power all time , the only problem in that the car runs in limp mode after 3500 rpm, whit drewdom file dhe dtc dos not apear anymore but the car stil gos in limp mode, i have replace n75 valve and turbo , map,map and check vacums ,evreithig but stil have same problem , limp mode can de desambled?
  19. #14
    upload screen shot from VCDS with nominal/actual value when car have reach 3400 rpm in 3/4 gear !
    Full WinOLS user
  20. The Following User Says Thank You to mihaiservice For This Useful Post:
    drewdom (10th June, 2016)
