if you use reset key position wait 18 seconds in a then off and is ready to start
hi , i need some help with this.
the car is 0 keys , this is the file of the immo ecu 89780-02120 93c56
i have one tp, i need if someone can put it in file.
thanks in advance!!
corolla 2009 ecu 89780-02120 ori fraga 93c56.rar
a2000 (21st June, 2016)
key added.....
No Thanks, No Report = No HELP
ill try and report.
thanks!
i couldnt make it work, its there a immo off or something to make it start? thanks
one of my post there 4d off file plz download it putt in ecu eprm r57 93c56 socond if there is 0 key in immo than car is ready to auto key learn replce 4d transponder then chack it
hi rashid01 , i couldnt find in your posts any off file for this ecu, the ecu has a rh56 eeprom and the file that i upload is from the immobox that has 93c56.
can u help me telling me which file i have to put in ecu and which one in immobox? i dont care if immo keeps working i just need it to start.
thank u in advance and sorry i couldnt understood before
Always show appreciation to ur helper NO + THANKS = NO HELP
elnikoa88 (8th June, 2020), joaquinoyola (28th April, 2023), kyawkyaw (3rd September, 2019), sfrank22 (25th August, 2019)
thank you aketokediag! but i tried it many times, in swap mode also and light keeps blinking and car wont start. tried with a id67 , and id68 also.
its there any other way?? .
thanks!
Did you use my dump? am very sure my dump should work for your car, because have prepare it to auto-learning mode, except your vehicle have electrical problem. Use ID70.
Regards
amigos buenos estoy intentando abrir el arcoo pero me pide contraseña gracias
Hello friends, I have this same problem with Toyota Corolla 2009, can you help me with the password to open the dump file, thank you very much .. regards...
Right now I have a Corolla year 2009, the origin is Brazil, there are no keys and I am going to do the process with UPA.
hi are doing friend, you can send the pass.thanks
