Results 1 to 5 of 5
    Default Audi ,idle speed
    I need help with increase idlespeed to 950 rpm , vcds can only change up to 900 rpm
    Thanks Regards
    Aug 2012
    Quote Originally Posted by blazej1200 View Post
    Thanks Regards
    you can test i hope i have all found
    pass in pm
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
  3. The Following User Says Thank You to icezero2010 For This Useful Post:
    blazej1200 (10th June, 2016)
    Andrei2015's Avatar
    Oct 2015
    You can do this with Vcds also
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
    Quote Originally Posted by icezero2010 View Post
    pass in pm
    Your solution works well Thank you Regards
    Quote Originally Posted by Andrei2015 View Post
