OK, got it.
OK, got it.
where is the link for latest updates please?
I Need New Update Please
Friends will leave this software x431 mercedes benz cracked of May 2010 if anyone has any please post another brand new update I urge
http://rapidshare.com/files/391765895/benz_40.zip.html
Greetings from your friend Canek
Friends I want to give this database that contains all the pins opel until last year for programming of keys and alarm I hope they work well when you open the macros disable the vehicle from entering the pin and go and please if someone has a new X431 cracked update the post it urges me thanks and greetings from Canek.
http://rapidshare.com/files/391790851/OPELMX.xls.html
When I try to use the cracked software it seems fine initially, I see all the models etc, but then when you try to do the scan I get the following error:
Blah Blah Blah [SUCCESS]
Initializing SmartBox [SUCCESS]
Downloading Program [FAILURE]
Any ideas?
Can not be happening I recommend you buy a 4-gigabyte memory kington for your computer that will be faster this update to my work but I do not know what may be happening with your launch also recommend you try the software that went up the companion sunnyone .
http://www.digital-kaos.co.uk/forums/f104/cracked-software-launch-x431-53288/
Ami me that it worked well when I can get some more happy to share with you.
friends want to share these Specefic Manufacturer Ford DTC that is always within the tools.
http://rapidshare.com/files/39191657...c_DTC.pdf.html
Launch recently has changed design of the smartbox for X431. Software for new smartbox is not compatible with old one and vice versa.
Read this article about new smartbox Обновленные Launch X-431 Master и Launch X-431 GX3 it is in Russian, use google online translator if you do not understand Russian.
My friend UMBA I read the article and I think that might be the reason why you can not use cracked software I'll try to ask an expert if there may be a solution to your problem hopefully any of the partners also can help.
Please someone has an Ford and Audi update for the X431 in March, April or May cracked me very urgent I thank you in advance
HELLO !!!
I need soft for launch x431 en spanish language !!!?
Help me pleace !!!!!
