Page 114 of 169 FirstFirst ... 1464104109110111112113114115116117118119124164 ... LastLast
Results 1,696 to 1,710 of 2524
  1. #1696
    Oct 2016
    Thanks.
    So far no solution?
  2. #1697
    Sep 2009
    Yes I check 3 software diagun 4 and easy diag and idag but in diagun 4 serial number is in correct and idag ask dealer code and easydiag also same I want start my diagun 3 plz help me friend
  3. #1698
    Brayn's Avatar
    Oct 2015
    Colombo
    hello
    i have Launch x431 iv. it is not working because it have not software download correct and now it is expire. can i use cracked software for this or have any other system to work this scanner?
  4. #1699
    Jan 2018
    thank you for help
  5. #1700
    Mar 2017
    Hi launch pros ,
    What are latest cracked updates for Diagun III?
    Will i be able to use the Diagun folders on tablet?
  6. #1701
    Sep 2009
    there no way now i tried my best to work diagun 3 red box with any tab but not succes can any one help you out
  7. #1702
    Jan 2018
    I have a launch Diagun III my 1 year of free updates ran out March of 17 Does anyone here know of a way or where I can get the latest or later updates for this unit?
    Thanks to all in advance.
  8. #1703
    Mar 2017
    Johannesburg south Africa
    Quote Originally Posted by andres04081988 View Post
    tengo un lauchdiagu x431 980543692800 y no hay manera de cargarle un software ayuda
    ENGLISH ONLY FORUM! Bro use english
    When you use the
    THANKS and REP Buttons
    it gives energy to help more
    Appreciation is the key
  9. #1704
    Jun 2013
    HI
    It will not let me download the attachment
    Feb 2018
    Hi Guys. I'm trying update my X431 Diagun with X431 Series Update Tools but the software do not recognize the vehicles files when I select the source folder. What could be happening?
  11. #1706
    Apr 2011
    Question Diagun iii Common Problem
    Quote Originally Posted by aqua_life View Post
    Hello,
    I have a problem with X431 diagun III.
    When I start it, it shows an error. It says: "No power! System will power off".
    I start the tool, then it shows this error and then it turn OFF by itself.
    And the tool doesn?t accept charge. I already tried with another battery but the problem is the same.
    How can I solve this problem ? Is possible to make a reset ?
    Attached you have a photo of the error.
    Diagun III Common Problem easy fix by reflashing tsop with good Dump 100%:
    No power ! Sistem will power off
    boot up stuck
    The "No power! System will power off". was fixed by reflashing the unit with a good bin, I have fixed thart in mine, Also another common problem is that it get stuck in the boot logo, wich can be fixed by reflashing with a GOOD dump of the flash, not found here, Couse I tested all and are bad dump, got it from another good unit from a friend, Thanks!!!
    I need an update for my diagun, the latest from 2017,2018.
  12. #1707
    Sep 2009
    can you upload dump for diagun 3 i was very thanks full to you i have same problem thanks
  13. The Following User Says Thank You to ford2002 For This Useful Post:
    rain2018 (21st June, 2018)
  14. #1708
    Feb 2018
    Hello again someone help me with fjl software for Idig x431 android S/N 965290010723
  15. #1709
    Feb 2018
    de donde eres
  16. #1710
    Jul 2010
    somewhere
    Hi Mate.
    I need one update for x431 idiag....
    I pay for it....
    Please write pm!
    Thank you!
