Results 1 to 4 of 4
    leandroks's Avatar
    Brazil
    Default Nissan livina smart key programming
    Hi there, i am trying to program new nissan livina proximity key, this car has no start button but a regular ignition switch, wich u have to turn it as a regular one, but no need to insert the blade when u got the smart key on you.
    the problem is i can program the transponder for emergency key but the remote never works, is there a special trick do do so>>>??
    Thanks in advance.
    BR
    Leo
    siyadk's Avatar
    Dec 2012
    after programming mechnical key with transponder , then you have to register intelligent keys, Did you try it?
    To be specific in T300 procedure: type 9> spl func> register inteligent keys>press lock button once
  3. The Following 2 Users Say Thank You to siyadk For This Useful Post:
    leandroks (13th June, 2016), p1et (13th June, 2016)
    leandroks's Avatar
    Brazil
    i ll try and let u know
    i was using fvdi.
    I ll try with t300
    thanks..
    leandroks's Avatar
    Brazil
    Thanks m8 the option is number 10 proximity key programming, no need pass.
    Worked like a charm.
    BR
    Leo
