Hi guys,
I need an original BDM read from a Mercedes-Benz Sprinter 318 3.0CDI
EDC16CP31 CR4.30
A6429003800
sw: 1037505819
hw: 0281016336
I prefer a virgin dump but just the full BDM read works fine.
Thank you!
Hi guys,
EDC16CP31 CR4.30
A6429003800
sw: 1037505819
hw: 0281016336
Thank you!
Fgtech can make this ecu
FGTech cannot do this ecu, I already tried
BDM100 reads and writes it, since the the mic is not MPC5xx but SC9xxx.
here is full bdm 100 read but original galletto read and write it 100%
Thank you but i need 505819 version.
Thanks anyway!
Upload your read dump and I or other guy can make a virgin
DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
it is correct wersion only file name is wrong
Ok. here it is the BDM read of the flash.
Can someone make it a virgin, please?
aslamaslam (4th May, 2019), rtxauto (26th March, 2019)
Problem solved! Thank you for the replies!
Essayer avec fvdi ?a marche bien
Nope, I assure you FVDI or MB START can't help in a case like this. Ecu flashed incorrectly, parts of the file were broken. I found a BDM dump from another Sprinter, moved the immo part, keys(working ones), the VIN number and some other stuff, flashed it and it runs
hi my freind
plz i have a big problem whith sprinter
can you guive me your vergin file from sprinter
regards
