Results 1 to 8 of 8
    May 2016
    Miami
    Default Some questions understanding checksums for ECU flashing
    I read my original files from my DME using EU KTAG/KTM100 clone and now I have 4 files:
    ECU - .DIM
    Micro- .MPC - 4096K
    EEProm - .E2P - 64K
    Tuning File - .DTF - 4096K
    I am planning to send my .MPC file for tuning service and I understand I must correct checksum before writing the tuned file to the ECU.
    How do I make sure KTM100 corrects/calculates the correct checksum? When i attempted to write a file it asked me If I want to correct checksum- if i click Yes, it asks me for the original file. is this normal?
    After the KTM100 writes the file- if i read the DME again will I see the same original AD53 checksum?
    Nov 2013
    UK
    Almost all files have a checksum inside, they vary depending on ECU type. Most checksums are calculated while writing with decent tools.
    KTM100 should calculate most checksums as it is a clone of Trasdata which is a decent tool. Yes its normal for it to ask for original file for comparison and then creates checksum based on changes.
    If you read the file again it will not be the same because the file is different.
    DONT FORGET TO LEAVE THANKS + REP!!
    DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
    EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
    May 2016
    Miami
    got it. thank you for explaining that. I thought the tool would force the old checksum on the edited file
    Jun 2016
    Did this work for you? First time using mine. I had a Volvo C30 D-4 which has an edc17.
    I read the files with my KTM100. I had the modified file back from an Alientech dealer and when I tried to write it to the ecu it asked me to check sum, it came back saying checksum error. I continued anyway but the car would not start so I had to dump the original file back in and call it a day
    I can't find any info on this and doesn't help that I am new to the ktag100. The v6 seem to do this automatically. Any help advice would be greatly appreciated please as to how to work this properly
    jakkeviet's Avatar
    Apr 2012
    can you send file ?
    Quote Originally Posted by Roncella View Post
    Jun 2016
    Hi do you mean the mapped file I has sent me or the original one I read please?
    jakkeviet's Avatar
    Apr 2012
    send both files
    Jun 2016
    Many thanks, I am working away next week but will send all the files when I am back. Can I up them here or send to you directly?
