Results 1 to 15 of 23
Thread: Clio 3
    Jun 2016
    Default Clio 3
    i changed the mileage in clio, Visteon, eprom 24c04, with digimaster3. I read the eprom after changing and the new mileage was ok. When i put the dashboard in place and turn on the ignition the original mileage come again.
    Any help?
    Dufner
    Johnner's Avatar
    Éire
    That's because you haven't done the ABS
  3. The Following 2 Users Say Thank You to Johnner For This Useful Post:
    cordeiro (16th June, 2016), PierreTheron (15th March, 2017)
    Jun 2016
    Changed the dash and that one kept his own mileage, so why did'nt change?
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Jhonner said you why not
  6. The Following User Says Thank You to jomberykaso For This Useful Post:
    Dufner
    Johnner's Avatar
    Éire
    Yes,the eeprom kept the new mileage in it....UNTIL you turned the car over...Then the new mileage got overwritten with the old data..
    Again,refer to post #2
  8. #6
    Jun 2016
    I mean i tried another dash and the mileage was'nt overwritte. So why does the abs do that with the original dash modified and not with the dash of other car!
  9. #7
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Because Digi is a fud?
    This is Clio3 mate, don't hold mileage in ABS.
  10. #8
    Jun 2016
    So, i'm back to the post #1
  11. #9
    Mar 2015
    disconnect battery put dach back reconnect battery thats all. Lupu Sandu is right no mileage in ABS clio 3 only 4
    DONT FORGET RADIO CODE IF YOU HAVE AN ORIGINAL RENAULT RADIO
  12. #10
    Jun 2016
    I did that and no result. The original mileage came back.
    Any else?
  13. #11
    Mar 2015
    Thats really strange wich year is your clio 3? are u sure its a clio 3? not 4
    i deed this one many times with digiprog never had a problem.
  14. #12
    Jun 2016
    2012. I did it with dgimaster 3.
    Did the same to a clio 3 2007 and got the same problema.
    Could it be the machine?
  15. #13
    Mar 2015
    renault_clio_2012_1uncrashed.gifNo i dont think so ! but try to do it with digiprog if you have it or with fvdi.
    By the way is this the clio yre talking about?
  16. The Following User Says Thank You to garabounga For This Useful Post:
    cordeiro (17th June, 2016)
  17. #14
    antenor's Avatar
    Here
    Or put the dump here.
  18. #15
    Jun 2016
    No.
    I'm talking about clio3 and your picture is a clio4.
    I just have the digimaster 3. If sameone coud send a dump with 81000 i would try to load it.
