Results 1 to 11 of 11
    Default Marelli MJD pinout for BDM
    Hi!
    I need pinout for BDM read Marelli MJD6f3 for FGtech or ktag..
    Thanks!
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Friend, the CD or DVD software you have the PDF with the instructions, or use google and search pdf
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    I have PDF but on pic is conection with probe, i dont have it and need solder..
    carmageddon's Avatar
    Italy
    Quote Originally Posted by AnixoR View Post
    Hi!
    Thanks!
    this is for 6jf and 6f3
  5. The Following 3 Users Say Thank You to carmageddon For This Useful Post:
    azibi130 (16th September, 2016), Doru Lucian (28th January, 2018), songokus (12th January, 2017)
    i dont have probe..
    can i connect like this on ecu board?
  7. The Following 6 Users Say Thank You to AnixoR For This Useful Post:
    Doru Lucian (28th January, 2018), Grucha1982 (12th July, 2017), karimdiag (11th November, 2019), Kayhan 17# (6th April, 2024), mendox (21st November, 2022), raskolnikov1975 (21st February, 2021)
  8. #6
    Aug 2012
    Europe
    yes that is good pinout
  9. The Following User Says Thank You to Tes1a For This Useful Post:
    AnixoR (17th June, 2016)
  10. #7
    spychu14's Avatar
    May 2011
    POLAND
    With that pinout everything works with galletto. Remember about resistor and galletto cannot make chk on this ecu. All changes must be made with winols and checksum corrected.
    VAG
  11. The Following User Says Thank You to spychu14 For This Useful Post:
  12. #8
    I made full read ok with this pinout..
  13. #9
    Jun 2012
    i dont have probe..
    The GND in bdm port on ecu is not in correct position in this pinout. GND is next to pin 1.
  14. #10
    Mario3's Avatar
    Dec 2014
    Quote Originally Posted by cawadany View Post
    Correct, and the one on pic. On every bdm port with mpc5xx, pin 3&5 are both grounds and connected together. So pic is good
    Sent from my SM-N9208 using Tapatalk
  15. The Following 2 Users Say Thank You to Mario3 For This Useful Post:
    cawadany (15th July, 2016), Kayhan 17# (6th April, 2024)
  16. #11
    Jun 2012
    Quote Originally Posted by Mario3 View Post
    Ok, I understand. Thanks for explanation.
