if the program you want to use doesnt connect to any external hardware why dont you use vmVare and install XP as virtual pc , copy the program to virtual XP and run it there. Easy does it.
Not a specific program, I know I can do that under compatability. I need to run a program via the CMD and it won't let me do it on Vista, I need to have XP. I don't want to download XP and install it as I'll lose everything on my hard drive so I just want my Vista to think it's XP. Is this possible?
Cheers
create a partition on your hdd and install xp on it. or create a bootable disc for the program
Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cable screw you nag3
well i dont think ya can make vista like xp i think xp is
better don vista xp faster for some reason.ya can get
vista to look like xp but have to down load it but will still
be the same it wont be any faster
What do you need to run under cmd?
if its dos mode then just install dosbox or simmilar, if its NT mode it should run without a hickup.
