there is eeprom chip in sid807. it?s under capacitors. need to pull circuit board off the aluminium case.
Hi all, have an 2012 mondeo 1.6 diesel. Original ecu is damaged and i got an doner ecu but never exchange sid before, any help will be much apriciatted,if i read ecu and transfer to doner will that start my car? Do i need to do new key after?. Thanks in advance.
Sent from my SM-G925F using Tapatalk
lush29 (18th June, 2016)
move that from original to donor ecu
Should be all good.
Is really no one there to give a bit of info about this?
First you have to read and save eep and int flash files from original ecu with Ktag/Trasdata or other similar tool !
Read eep/mcu and save from second and than try to write original eep and mcu,if there not are OTP area than car should start !
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
lush29 (21st June, 2016)
Update_ i try to read ori ecu but is no connection with ktag. With doner ecu is ok . Any other way to do this ecu? Or tool?? Thanks
The only one way are with Ford IDS,if donor ecu are in good condition just reset ecu with IDS and recode again !
Full WinOLS user
lush29 (30th June, 2016)
Hi, bit of an old topic but I have similar issue with dead Volvo V50 SID 807 EVO ecu and would like to what component you were talking about moving in this post? Thumbnail/picture not active anymore?
Would appreciate any help in finding out what needs to be moved to the new donor ECU.
Hi, is it possible to read Original ECU EEprom?
P.S. Better to create a new Thread.
