Results 1 to 5 of 5
    Aug 2008
    Default Using Damos files in WinOls
    Hi Team. I thank anyone who helps in advance but i am a newbie so please be gentle.
    I have WinOls and over 10gb of damos files at my disposal and am looking for a idiots guide to using the Damos files with ECU configs i remove from my vehicle and any other vehicle.
    Can anyone point me in the right direction please?
    Nov 2012
    smartville in front of a OBDplug
    make sure to have the last version of ols521 damos importer
    because lot problems have been resolved since begin of year !
    as bytecoding and some other 1D maps not existed in winols before this year
    Date
    Version * Change
    06.06.2016 4.022 Fixed Crash on special data fixed
    02.06.2016 4.021 Fixed Crash on very long map texts
    30.05.2016 4.020 Fixed Wrong offset for maps with mixed bit width
    12.05.2016 4.019 New New import option: Store descriptions as map comment
    04.05.2016 4.018 Fixed Moved start address for some 1d maps
    04.05.2016 4.018 New Another options how name/id can be imported
    04.05.2016 4.018 New Faster
    02.05.2016 4.017 New Folder import improved
    21.04.2016 4.016 Fixed Problem with some float 1d maps
    17.02.2016 4.015 New Import of Audi maps with vertical axis now possible
    22.01.2016 4.014 Fixed Import of some special 1d maps improved
    13.01.2016 4.013 Fixed Import of A2L files improved
    01.12.2015 4.012 Fixed Wrong sign flag in some axes
    19.11.2015 4.011 Fixed Problems with some axes
    30.09.2015 4.010 Fixed Fixes a problem for 1d map axis from previous update
    28.09.2015 4.009 Fixed Possible misdetection as multi-bit-map
    17.07.2015 4.008 Fixed Import errors on some projects
    14.07.2015 4.007 Fixed Factor/offset were sometimes imported wrong
    30.06.2015 4.006 Fixed Some maps were imported incorrectly
    08.06.2015 4.005 New Import of bit fields
    15.04.2015 4.003 Fixed Wrong address for some 1d-maps without axis
    15.04.2015 4.002 Fixed Crash on certain data fixed
    21.03.2015 4.001 Fixed Problems with 1d maps
    19.03.2015 4.000 Fixed Wrong axis positions
    09.09.2014 3.041 Fixed Import didnt work for a new file variation
    14.08.2014 3.040 Fixed Problem when importing 1d float maps
    07.08.2014 3.039 Fixed Now also fixed for 1d maps
    06.08.2014 3.038 Fixed Some axes were ignored in some files
    27.05.2014 3.037 New Import of A2L files improved
    23.05.2014 3.036 Fixed Some A2L maps were imported wrong
    21.11.2013 3.035 Fixed Problem with 1d maps fixed
    26.09.2013 3.034 Fixed Import error for some A2L maps
    20.06.2013 3.032 Fixed Import improved
    20.06.2013 3.033 Fixed Problem with Windows XP
    22.03.2013 3.031 Fixed Improved Demos import
    21.02.2013 3.030 Fixed Possible crash on older PCs
    11.02.2013 3.029 Fixed Damos 1d-import sometimes didnt work
    10.02.2013 3.028 Fixed Damos-import improved
    06.02.2013 3.027 Fixed At some files 16bit maps were imported as 8bit
    17.01.2013 3.026 Fixed Might crash on some older PCs
    Aug 2008
    thank you. that done the trick. do you know where i could get the csv files for damos files? when i import a damos file is thatmy original already mapped or is it just pointing out the sections and what they are called?
    Apr 2013
    it is just pointing out the sections and what they are called
    you can get them from users and foruns
    Don?t forget to mark "Thanks" if I helped you
  5. The Following User Says Thank You to GabrielMga For This Useful Post:
    wwhitty (20th June, 2016)
  6. #5
    Aug 2008
    Ah thank you. So how do you transfer the modded file to the original file. Excuse my ignorance but you have got to start sumwere. :-)
