No one a solution?
No one a solution?
File is packed and encrypted, no possibility make any change without decryption.
Recommended not wasting time for this file.
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
bubu69 (20th June, 2016)
I don t want to make changes,
i only want to read this with winols, like i do with 80% of the other 0da files.
And i don t understand why this file should be encrypted and most of the other 0da files not.
So maybe that's not ECU dump. That's sure you will be not able see this file in WinOLS.
need 0PA and 0DA file
i can decrypt
WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
Fileservice
no thanks no pass
bubu69 (4th July, 2016)
@baddog84
Would you try it
Maybe someone else know how to encrypt file
