Hello,
I have two Axone 2000 that do not work. They have the exact same problem. When I press the 'on' button, both units beep a long 4 second beep and repeat over and over. There is no screen turning on. If I press the 'on' button again the beeping will stop. It will do this with all modules.
The 7.2v battery is new and fully charged. I have not tested the internal 3v backup battery. The units sat for four years in storage.
Is this repairable?
If it is related to the bios file I cannot update it if I can not turn on the unit... but it might be that the units are bricked.....
thank you
