Lambda off, crc ok, Pass sned to PM.
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
small problem with this file cruise control not working any other solution ?
send full diagnostic from VCDS on ori file.
HOT/COLD START
TRANSLATE DAMOS ENG
START/STOP ON/OFF
Manual solution
CRC OK
I did modify ESKONF too so you can unplug both post CAT O2 sensors (if you like).
Do you keep CATs? I didn't touched catalyst heating.
022906032AK (VW Phaeton (Rear O2 OFF) - 371108).zip
tiugrikas (21st July, 2016)
!!!!!!!!!!!!!!!! working very good thanks a lot my friend !!!!!!!!!!!!!!!!!!!!
phaeton eeprom
