upload files my friend if you did something wrong this ecu will be your nightmare.Then you must have good tools to fix it
I would like you to help someone with ecu simos pcr2.1
Written without becoming unlock, with the result that the engine starts, we can not make a diagnosis, nor to write it again. the file went to write was correct.
the we can do to fix it again ..
Get ecu from car, make backup, unlock eep, use factory file to restore flash. All will be work.
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
It was inadvertently ....
I again fix such without any problems.
with what has now become the eci not works . because we wrote the ecu without making unlocking
did u have VAS or VCP or other tools what able writing FRF/SGO file ?
If not i can give you factory file to other programmer but for that needed use ex KESS recovery.
If ecu not respond at upper way only possibility is get ecu, boot mode, unlock it, then make factory restore
