Page 1 of 2 12 LastLast
Results 1 to 15 of 29
    hass42's Avatar
    Aug 2012
    USA
    Default Audi Gateway Module
    Hello all,
    I have virgin a donor dash with abrites on 2014 A5 and now need to read load gateway flash.
    Anyone can help in location of gateway in vehicle and what chip do I read flash from?
    Is the gateway the J533 ? Module cause I keep reading different on this, says its a audio gateway and others say its can gateway for diagnostic
    Found this picture, is this the one?
    If so what chip to read flash?
    Feb 2010
    In EEP
    this is getaway together for audio (optical)and for diagnostic can (uds). this is ecu you need read.
  3. The Following User Says Thank You to vasa For This Useful Post:
    hass42 (24th June, 2016)
    hass42's Avatar
    Aug 2012
    USA
    Quote Originally Posted by vasa View Post
    Thanks for this info,
    Do you know what chip I'd have to read?
    hass42's Avatar
    Aug 2012
    USA
    anyone have the pinout for this gateway? to read flash?
  6. #5
    Jun 2010
    EU Romania
    MCU or some eeprom if exist, check if you have some eeprom on PCB ?
  7. #6
    hass42's Avatar
    Aug 2012
    USA
    I do, but I thought Avdi asked for flash file
    Eeprom is next to mcu to left
    Hass42
  8. #7
    Jun 2010
    EU Romania
    Can you make bether photo with Eeprom next to mcu to left and with MCU to see what is writhen on this ?
  9. #8
    hass42's Avatar
    Aug 2012
    USA
    Customer has taken vehicle for now, I will have next week.
    I just need to rear flash from this gateway and initialize cluster and I should be ok. I hope
    Hass42
  10. #9
    soxten's Avatar
    Mar 2013
    Upa-usb-s can read 1M034Y if it is not locked.
  11. #10
    DK Veteran markony79's Avatar
    Jan 2009
    Sweden
    use Xprog-m original, 3 minutes jobb
    work good
  12. #11
    hass42's Avatar
    Aug 2012
    USA
    Avdi asks for reading of eeprom 25640
    Is this the smaller chip next to 1m034y ?
    Hass42
  13. #12
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    95640/25640 on gateway
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
  14. The Following 2 Users Say Thank You to lupu_sandu For This Useful Post:
    hass42 (29th June, 2016), mike870 (9th May, 2019)
  15. #13
    hass42's Avatar
    Aug 2012
    USA
    Ok great so the 8 pin eeprom? Not mcu?
    So file from this for Avdi is correct?
    Hass42
  16. #14
    hass42's Avatar
    Aug 2012
    USA
    Ok I read that chip and not right config file
    And my xprog not working.... I have software from xprog and hardware is Chinese.... hardware failed
    Hass42
  17. #15
    hass42's Avatar
    Aug 2012
    USA
    Quote Originally Posted by markony79 View Post
    work good
    I have xprog 5.5.5 now working, whatdevice would I use to read this?
