Results 1 to 4 of 4
    May 2016
    Default Mitsubishi L200 2.5 TD 115cv E6T0x read/write
    I need help how to read/write flash from this ECU.
    I have tried by KTAG on table but no possible. Maybe something wrong.
    moky's Avatar
    Behind you
    good ktag work fine on this ecu on table ..check connection if not work your ktag is bad....
    May 2016
    Solved. I use galletto v54 read/write without any problem. So Do you think that the Ktag is bad? Do you know how to fix this?
    moky's Avatar
    Behind you
    if don't work on this ecu for sure it's ktag problem
    search on forum for fix ktag
