Gery (22nd July, 2018), sonic 1989 (13th March, 2018)
here
--> ASTRAJ_DPF_chck.rar
baronrojo (31st March, 2022), Gery (22nd July, 2018), lupu_sandu (27th June, 2016), netmasters (15th November, 2022), phl0at (24th January, 2017)
I will have 100% working solution for 2 months...
It is necessery to read it in boot mode or BDM. If You read it by OBD You won't erese DPF counter...
I will share it with You for free(which I already bought) if You will wait...
You can read it by k-tag 7.003
If my solution helped You - do not forget to THANKS !!!
Yes. I bought solution and I sent a file which I readed by KESS same as You. DPF is removed from program, You can ride it, but in ECU is still DPF counter which is in sector non readeble by OBD. I'm waiting for K-tag 7.003. When K-tag will come I will read it in boot mode and I will send it again to gay who I paid. Then I can send it to You.
lupu_sandu (28th June, 2016)
time ago I make with obd and runs perfect...
lupu_sandu (28th June, 2016), nizarben (22nd November, 2016), Zaklberg (29th April, 2019)
kinketotua: Car is running with your file. So far, so good.
My Car was driven 500 km until check shows up...
If You have solution to cut it off without uncover ECU You are GOD...
OPEL ASTRA J 2011 A17DTF
DELCO E87
HW 55584317
HW ver. 86AA6PH012620056
SW 55597679
As I said time ago (posible one year) I make one like these software and I supose that they make more than 500kms until now...
But lupu report please the process
lupu_sandu (29th June, 2016), nizarben (22nd November, 2016)
Is the file OK ?
Hi please password from files dpf off
here your file number7
--> Attachment 385378
number7hd (8th July, 2016)
THANKS kinketotua but it doesn't worked. But I'm not sure if I have upload it well.
An upload I have made by KESS but there already was MOD (Swiftec solution).
By uploading file KESS asking about file to upload, then about file to compare (original) - so I have selected file SWIFTEC solution becouse it already was in ECU.
After that Car didn't start. ECU was alive becouse there was connection. Error was that FAP is clogged.
So I upload SWIFTEC solution choosing file as original to compare ORG file first readed not Yours DELCO_dpf_chck.mod and Car starts.
I'm wondering if when I upload DELCO_dpf_chck.MOD choosing ORG file if it will works?
