doctore (9th December, 2017)
A noob question guys, when you connect pin1 to pin 16, then how do you plug the obd lead in? jump wire at the back of the obd plug?
Hello.
yes exactly jump wire at back of obd2 connector not at face of obd2 connector, if you work at all on vag group you can order this tool > https://www.chiptuningshop.co.uk/pro...ignition-tool/
doctore (10th December, 2017), haroutioun (10th December, 2017), Jobeso66 (11th December, 2017), mickye_dj (1st June, 2018)
see here same car.2,4 engine but same ecu type
https://www.youtube.com/watch?v=mqSmvsQby-g
eprom type 95320
with this data rest can be done
vvdi2 do it.
to get diagose to the car switch on lights and hightbeams.on and off to wake up the car bus.
i have fvdi and vvdi2
and can say fvdi do this car easy
haroutioun (10th December, 2017), yugo45 (11th December, 2017)
Dissamble the steering colum.
The ELV (J518) is in there, and holds all the data that is needed.
Many programmers can read these.
You could even add a transponder to its dump.
with cs+pin you can teach in new dealer key.and aftet this add new key.
why dont look on video?
i have audi a6 4f rom 08.2004 2,4 petrol.it works on my car.
Thank you , That will be my next step if I don't have success with VCDS tomorrow , I kind of made a pre - disassemble inspection , it seems that I need to unscrew 2 visible headless bolts under steering column pointing downwards , I'll make a groove with dremel tool and unscrew with. Large flat screw driver ,
my vvdi pro read it with clamp
Jobeso66 (27th December, 2017)
