Page 9 of 10 FirstFirst ... 45678910 LastLast
Results 121 to 135 of 150
  1. #121
    Dec 2016
    Quote Originally Posted by dimet View Post
    It will be good if you can try it on a car new function all key lost added. I bought one F108 + yesterday.
    if it's like FVDI and kill the BSI , i prefer another test it on destructed car , PIN code cost is 5€ in France .
  2. #122
    dimet's Avatar
    MKD
    They may have been copied from TDB007.
  3. #123
    dimet's Avatar
    MKD
    Has anyone tried the new function all keys lost?
  4. #124
    Dec 2016
    2014 Peugeot 208 , Hella key , fail to program key * " error ID type transponder ... " message , dont test with Diagbox
    PIN code read OK in 5 seconds , all key lost is the only option available to this car .
    * i use CE0536 FSK
  5. #125
    dimet's Avatar
    MKD
    Peugeot 308 1.6 hdi 2010 read pin and program key CE0536 FSK done.
  6. #126
    Apr 2016
    Testing H108 so far 207 pin OK
    307 2003 pin not OK all options
  7. #127
    Sep 2016
    Quote Originally Posted by TERMINATOR1000 View Post
    * i use CE0536 FSK
    Some Peugeot/Citroen use hitag3 remotes. It can be this case(I don't know when 208 had facelift etc)
  8. #128
    Dec 2018
    207 2011 work 4 or 5 on off ign
  9. #129
    Dec 2016
    hi bought a f108+ one year ago test to my citroen c3 2010 but not pin reading
    anyone have a update of this tool?
    thanx
  10. #130
    Dec 2016
    hi friend i finally got the pin code and it s working for reading i let the door open and for me works take 5 min for reading
    need to confirm the pincode with diagbox to be sure the reading it s good thanx
  11. #131
    Jul 2019
    Me too wasn't able to read the key but has read the EEPROM data which I have used on this forum to get the access code.
  12. The Following User Says Thank You to JAVA For This Useful Post:
    mista1234 (22nd July, 2019)
  13. #132
    Dec 2016
    hi friend did you read on citroen c3 java? can you explain which error message do you have ?
    regards
  14. #133
    May 2018
    Quote Originally Posted by delek View Post
    F108+ ver. 31.25
    Citroen C3, Engine KVF 2005 reading pin: NOT OK
    last version is 31.20,where you get 31.25?
  15. #134
    Dec 2018
  16. #135
    Dec 2016
    Quote Originally Posted by Alpaholic View Post
    better to use FVDI on Peugeot 308 , 100% Serial Killer
