If you know your way around E2 boxes yes easy set up if not just do a bit of reading on here and ask a few questions and you'll soon be up and running just remeber there are certain things we cant discuss regarding getting All channels good luck ..
As my F5 appears to have died I am looking at getting one of these.
Stupid question - I presume you can have both satellite and cable working at the same time?
when you say working
You mean watch one and record another
Yes this is possible with the right files inputted...............Paul
PAUL
I also like the ability to watch one channel and stream via the openwebif plugin (built in) to a PC, tablet or mobile phone.
hi am new to these zgemma h2h box and only need to use the cable side is there anyway of doing without using a line a have vm
without the added bit all you can use box for internet plugins like tsmedia or kodidirect,tv channels i believe are 1-5 only.
Cool will probably look into installing firezilla and learn to add a line.
Sent from my SM-G920F using Tapatalk
