Any suggestions?
Hey guys
So I have a problem. I cannot read this ECU from Jaguar X-Type 2.2TDCi with Delphi MP555 with Spansion Flash.
This car currently has DPF issues and we wanted to do a DPF off.
Anyway, i managed to get an ECU from a non DPF model.
Is there anyway to adapt it using JLR SDD to the car as the motors are same.
Also, upon trying the original ECU in the car it doesnt start, not even cranking. Fault codes are immo related. Could the original ECU lost its coding some how? We have communication with the ECU and everything else is fine.
Any suggestions?
yes it can be done dpf off on your ecu.
read the both ecu and send it to me and will make you adaptation
DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
jaguar_2.0l_2008year_full_maps_.zip
I need DPF-off for $$$ Jaguar x-type 2008year 2.2l
