Results 1 to 13 of 13
    Lithuania
    Default Renault megane DF226 P0120
    Need help to remove TVA, flaps error and function. Error I can remove in DTC table, but cant remove function, and car still in limp mode
    Car Renault Megane II, 1.9 DCI EDC16C36 2006 sw 395740
    Lithuania
    Any one can help?
    Lithuania
    No need free solution, I can pay for it!!!
    kinketotua's Avatar
    Apr 2016
    Europe
    here
    unplug tva
    --> Attachment 385059
  5. The Following User Says Thank You to kinketotua For This Useful Post:
    Min2xx (5th July, 2016)
    Lithuania
    Big thanks, but solution not work, after 2-3 starts limp mode and no errors. I tested this solution before. Not Ok
    kinketotua's Avatar
    Apr 2016
    Europe
    you unplug??
    Lithuania
    Ok, will check again tomorrow
    Jan 2019
    Quote Originally Posted by Min2xx View Post
    So, what causes your dtcs df226? It could be cars ecu dead?
  10. #9
    Lithuania
    No, it is TVA error, if car not start, maybe TVA stuck in closed position ?
  11. #10
    Jan 2019
    it is open all the time.
  12. #11
    Jan 2019
    If I buy a uch, engine ecu and a card key from the same donor car, car would start with no dtcs if engine ecu was the problem?
  13. #12
    mapino's Avatar
    Netherlands
    Try this..
    let me know if you have succes
    From the netherlands
  14. #13
    Lithuania
    Quote Originally Posted by Andr33iy98 View Post
    Seems ecu problem ...
