Results 1 to 8 of 8
    Apr 2012
    wolomin poland
    Default passat b6 need pin form comfort module
    hi
    can someone get pin form this comfort module dump. its passat b6Attachment 385080
    Moderator
    PremierD's Avatar
    Jun 2009
    VIN: WVWZZZ3CZAP020136
    PIN: 36316
    Component Security Bytes: D0 B4 D9 19 A1 69 B2
    That do mate ?
    Apr 2012
    wolomin poland
    thats wired i read pin form ecu and itss different. i think they should match. can you edit thisdump if i give you cs pin and vin??
    here is dump form ecu you can check it
    Attachment 385083
    Moderator
    PremierD's Avatar
    Jun 2009
    Then one of them is wrong mate ............ And it is mine .... used the wrong file sorry
    Apr 2012
    wolomin poland
    pin i have used pin form ecu to login in to immo and its workink. this car is wired. customer had problem with stering lock. he send it to repair but man who repaired it wants bcm and key idk why. after repair stering wasnt working but car starts. he dorve few weeks then discontect batt. now immo is active im serching why i have posted ecu eeprom on post 3 can you look at it. i have avdi bu i could read bcm dump at all i dont know why even if i used dumptool it tells me decrypt error
    Apr 2012
    wolomin poland
    can anyone match bcm to ecu. i think ecu i ori in this car
    Top Poster oleg68's Avatar
    Jun 2016
    Moldova
    Quote Originally Posted by lonczyn View Post
    hi
    incorrect file size is 8 кв. Normal file has a size of 4 кв
    Apr 2012
    wolomin poland
    mate this is full read of bcm eeprom. i can try to read it again but i think it will chanke nothing.
    i reopened bcm there is 95640 not 320 this is reason to be 8kb not 4 i think
    bcm second read Attachment 385176
    Attachment 385189Attachment 385190
    everything i clear now. car i running just replace to new one steering lock
