taka fgtech and try, or bdm help you.
been trying to tinker with my ecu for a while, but i knew it might not be easy as it was already remapped when i bought it, but i finally got around to reading it today with MPPS V16, but as expected its encrypted
i got the message "this is a NOREAD file and has been encrypted"
ive done abit of googling and it sounds like it can be unencrypted but i have no idea where to even start with this
can it be done? and where is the first place i start looking?
i can share the file if needed but i cant seem to upload it at the minute
bobolin4o (6th July, 2016)
Read by BDM!!!!
like bdm 100 , k tag , even xprog can do this job
here you go http://carmasters.org/topic/295-bdm-%D0%B8-xprog-m/ you can do many ecus with xprog ! just one small problem reading and writing tooks longer than other tools but its normal !!!!!!!!!!!!!!!!!!! don't forget thanks button !!!!!!!!!!!!!!!!!
turbo16v (29th February, 2020)
well I had read protected ecu edc16u34 but it was enable read trough obd ! but bdm worked fine so may work too .
u can use mpps v12 with noread patch
Sent from my SM-G900F using Tapatalk
jmorek (19th February, 2021)
