Results 1 to 9 of 9
    Dec 2010
    Default Peugeot RCZ 1.6 THP Stage 1 REMAP
    Hello friends,
    Could you help me with STAGE 1 remap of this car?
    Peugeot RCZ
    1.6 THP 200HP
    0261S06152
    MEVD17 CEM0
    MEVD17.4.2
    9674183480
    Read by BOOT mode.
    Thanks in advance!
    regards,xdamdamx
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Default file for you
    Here you are,
    Try and report
    Don't forget hit thank button
    Pass on P.M.
    Greetz from Belgium
    Winols554_mod.rar
  3. The Following User Says Thank You to sdtsedat For This Useful Post:
    xdamdamx (7th July, 2016)
    Dec 2010
    Thanks, but having P061A -internal ECU Fault - looks like some limiters ?
    Only when pushing accelerator.
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Default new file
    Try these
    Must be solved
    Same pass
    Greetz from Belgium
    WINOLS554_MOD2.rar
  6. The Following User Says Thank You to sdtsedat For This Useful Post:
    Dec 2010
    Thanks again, but the problem remains. in ECU only fault is internal error - at about 5500RPMs.
  8. #6
    sdtsedat's Avatar
    Jan 2015
    Belgium
    When you flash ori file, no fault DTC code ?
    What do the car ? When you give full throttle, go the car in emergency mode ?
  9. #7
    Dec 2010
    yes friend, when i give full throttle after a while i get this error, and emergency mode. Ori file drives OK.
    no boost DTCs, or fuel DTCs. only Internal ECU Fault.
  10. #8
    Dec 2015
    PL
    Torque monitoring problem. Or tuned files are bad or You have to make torque monitoring off...
  11. The Following User Says Thank You to mateusz1611 For This Useful Post:
    boomeer (9th July, 2016)
  12. #9
    Mar 2016
    Turkey
    Bad tuned file
