you have any pictures of ecu to see if there is any damage
we flashed this ecu perfect with a mod, then customer comes back as has a dtc, so we had new file made,
and couldnt write back mod,
I think possibly bdm probe/s maybe not on exactly,
any one know what to check on ecu ?
all looks ok no burnt components, and no heat when we connected,
just need ecu working, now, where to start ? thanks
i have backed up eeprom and flash so not so bad if Fried and need replace,
be nice to try and repair tho !!!
now you cant connect bdm interface ?
what about obd ?
REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
No cant communicate with OBD for DTC scanner, no read or id on BDM,
Theres no damage that i can see on Board, try put a photo up later,
as i have flash and eeprom backed up, I can get any serial number ecu ?
Bosch edc16c from a focus ? Yes
or is it better to match number and re flash my good read,
pulsar2000 (10th July, 2016)
i may try for repair, any one recommend a good UK repair company ?
do you have the full bosch number
7.31sec@203.3mph
yes will put up photo of pcb and ecu number
tomorrow
cheers
part number 0281 015 608
anyone know if someone has one
