Audi a3 2009 8P0920931S dead - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 46
  1. #31
    Jan 2016
    Why you are sarcastic ?? These connections are from Xprog manual and not from my IMAGINATION. Your Micronas PCB is the same as in picture from X-prog manual which I posted?? I have ori X-prog from ELDB and it works every time if you solder wires and lift pins properly. Maybe you have poor quality Xprog-m clone ?? Sometimes X-prog try 5-10 times before bypass security.
    Quote Originally Posted by jamalazf View Post
    hi, Thank you for this picture but what tool it's necessary, i have one X-PROG-M V 5.0, I don't have a connection wire picture, I try with amigokola picture but don't work, In my X-PROG, I'have this message "Unable enter boot" error, it's Very hard!!!!!!!
    ThankS Mr AMIGOKOLA
  2. The Following User Says Thank You to amigokola For This Useful Post:
    jamalazf (15th November, 2016)
  3. #32
    Nov 2016
    FRANCE
    Default IMMO OFF EDC 16U34
    Hi, Someone can help for immo off edc 16u34 audi a3 8p 2009 eeprom 95320, Iwant to start my car, thanks
    ECUA3.rar (1.2 KB)
  4. #33
    Feb 2015
    Hello guys
    In five minutes it solves these problems with MRPPad
    You can do everything to VAG Micronas with this tool
    If you have a damaged flash you just read the immo data, the program automatically saves them, write a good flash and reload the immo data saved.......https://youtu.be/0Oc0VUwBNTE
    Quick and easy
    Inviato dal mio SM-T805 utilizzando Tapatalk
  5. The Following User Says Thank You to nafnaf2 For This Useful Post:
    jamalazf (17th November, 2016)
  6. #34
    Sep 2014
    Try and report ECUA3immooff.rar
  7. The Following User Says Thank You to Naidencho81 For This Useful Post:
  8. #35
    Apr 2011
    audi a3 2006 8P0920931S dash dead when i
    need reper
    thanks A3 2006 DACH 8P0 920 931.rar
  9. #36
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    Quote Originally Posted by INEGMA View Post
    need reper
    Your flash ok.
  10. The Following User Says Thank You to lupu_sandu For This Useful Post:
    INEGMA (22nd December, 2016)
  11. #37
    Apr 2011
    Thanks for your help .lupu_sandu
    Tomorrow I will send the result
  12. #38
    Apr 2011
    Thank you for your help.GOOD JOB
  13. #39
    Apr 2011
    can someon reapir my dump?
    Audi A3 8P0920931S
    24C32 + 3217G
    After someone change odo i have rom error
    Thanks in advanced
  14. #40
    BusCan's Avatar
    Nov 2013
    Default 8P0920931S
    I Have dashbord corumpu Audi A3 8P0920931S
    3217G
    Thanks for Help
  15. #41
    Quote Originally Posted by BusCan View Post
    3217G
    Thanks for Help
    Here you repaired file:
  16. The Following User Says Thank You to exe123 For This Useful Post:
    BusCan (17th January, 2019)
  17. #42
    BusCan's Avatar
    Nov 2013
    Quote Originally Posted by exe123 View Post
    Thanks work fine
  18. #43
    castin's Avatar
    Oct 2015
    Please, smoeone upload full dump for dash Audi A3 8P 8P0920931S - Thanx
    Im try replace flash form GB dash to EU.
    Thanx
    OK, solved. Im find on forum. Program and dash work.
  19. #44
    Jun 2019
    croatia
    Default Please Help my Audi a3 2004 to new cluster 2009 Micronas 8p0920931s
    Hello, please help with these files Audi a3 2004, I put a new instrument panel micronas cdc3217g 8p0920931s, that key with the lock, and the module of that car all in the kit, if you are able to read Immo Pin, or pair with this original file, The car starts for 2 seconds and goes out; ERRORS: 02241- ENGINE CONTROL MODULE, IMMOBILIZER DATA NOT ADAPTED, 16346 CONTROL MODULE-ROM ERROR, USING CARPROG, VCDS, MPPS
  20. #45
    BusCan's Avatar
    Nov 2013
    Default CDC3217G
    Possible to repair my Flash CDC3217G_secur
    Dash 8P0920931S
