any help ?
any help ?
change y83 shut down valves !! if valve is broken its can burn you ecu
P1189 este M55 cu motor admisie v?rtej, am nevoie off codul de eroare
now is without M55 and swirl flap
You can solve this problem with just 1 x 1 kom resistor, without any software changes.
Solder him between the "signal" and "+" of the actuator harness, M55 must be disconnected!
You can do this from the ECU side... Easy, fast and secure!
Cheers!
tutzu (14th July, 2016)
