Results 1 to 5 of 5
    Default Need dump Polo Simos 9.1
    I have Ecu Simos 9.1 POlo 1.2
    It fails cyl 3 (misfire), it is not HW problem.
    I tried cloning in other ecu ( same HW but diff Sw), then I discover that problem is in Sw.
    When I load original Sw in donor Ecu car misfires again. If a let Sw in Donor Ecu as it comes car runs good but it stores many error due to Sw differences.
    I need any full dump to load it (bootmode galletto)
    I tried updating with Odis but it doesnt start update ( I used it many times), so I need to update Ecu this way.
    Ver.HW: SIMOS91 1.2l
    SW act.: 03E906023D 9510
    5wp40502
    It is not problem what sw is, but at least than reference is the same.
    Or if is there any way to traslate .sgo file to .bin file so I can load it with galletto ( Odis fails)
    Thanks beforehand
  2. The Following User Says Thank You to GolfmkI For This Useful Post:
    liban11 (27th April, 2018)
  3. #2
    File is not needed anymore
    I have found it reading other exactly Ecu.
    File is exact as mine so my file is good, and is not need to update.
    The curious thing is car is running good with other Ecu ( not same software) but things now are clear.
    Software is not the problem of misfiring
    Ecu itself is not the problem of misfiring.
    Other Ecu ( not same software) works but many errors on it, could be these the reason is not misfiring with it.
    If we use Ecu and software that belongs to the car. It misfires a lot in cyl3.
    So mechanical problem on it.
    Car is the problem
    Thread is "solved"
    ONTOPIC:
    As file is 100% good you could save it, never Knows when you could need it.
    It is avaliable for many Skoda, Vw and seat.
    It is full read with Galletto bootmode
  4. The Following User Says Thank You to GolfmkI For This Useful Post:
  5. #3
    Mar 2018
    can you give me some photos how to read this ecu polo simens vdo petrol simos 9.1 Hw04 5wp40510 04
    with galetto boot mode
  6. #4
    Mar 2018
    Quote Originally Posted by liban11 View Post
    Just search for simos 9.1 bootpin to see it clearer and remember first bootpin to be soldered then put the red cable , in order to enter bootmode
  7. The Following 2 Users Say Thank You to pmptuning For This Useful Post:
    liban11 (25th December, 2018), scoot (8th March, 2019)
  8. #5
    Feb 2017
    What was the mechanical problem with the car?
