Results 1 to 4 of 4
    DK Veteran dollarbill's Avatar
    france,paris
    Default Porsche Cayenne 2003 v8 4,5L Nothing happening when i put the key
    Hi for all
    i have a cayenne in my workshop and nothing happen when i put the key the remote don't work when i open the door with the key and i put the key in eis only alarm work.
    I say the history the customer lost the key i make one with avdi all good the vehicle start remote work all good . The customer leave the car one week on the workshop i did a key . He came back but nothing the remote don't work don't start one week earlier all good . He phone me the key don't work . He bring it back in my workshop I check all fusible and relays and wires and battery in the driver side all good . I think the kessy is out i buy another and adapt but it's the same the car made me crazy . When i short fuse 26-36 and i diagnose i can read the fault in the ecu kessy etc and all fault and module is can't communicate with all module eis steering lock etc... I think no communicate can drive and confort but i check all fuses wires and relays all good if someone have a idea big thanks in advance for help
    if i help don't forget a thanks
    SPIROS2105's Avatar
    Feb 2012
    Greece
    i had a same problem and i solved with vag com
    did you fixit?
  3. The Following User Says Thank You to SPIROS2105 For This Useful Post:
    dollarbill (26th May, 2017)
    ohkarol's Avatar
    Oct 2010
    PL/UK
    first - resolder coil in key..
  5. The Following User Says Thank You to ohkarol For This Useful Post:
  6. #4
    rideon's Avatar
    RO
    There are a lot of wires to check on that car....
    If you have communication issues you can start with front bumper and finish with the rear one
    I'll search for water ingress, been raining lately?
    Misspelled using Tapatalk
    A failure will not appear till a unit has passed final inspection
  7. The Following User Says Thank You to rideon For This Useful Post:
