Results 1 to 4 of 4
    Top Poster girovend's Avatar
    Sep 2008
    Default Sorting Channels
    My m8 has an old Eurovox (dont know what type) he had to do a power scan
    and now his channels are all over the place,
    Is the eurovox not supposed to sort the channels out itself or is this just
    a feature on later models,
    If its just later models that do this I'll have to try and get him a CDF file,
    could someone tell me if the CDF files are compatible throught the eurovox range
    or do you have to get one from the model your using,
    smoggy's Avatar
    Apr 2009
    UK North East
    they are all compatable except the 700HD which uses the .tbn format.
    your best bet is to do a powerscan and then upload your cdf to the PC and sort it using Voxer then download it back to box
    you can get Voxer here Digital Kaos - Downloads - voxer eurovox 1 . 2 installers
    I'm new to this aswell! So After, you get your box, you scan it amirite? then, you sort the channels out your selfes? someone drill this down for me plz!
    badapple's Avatar
    REQUEST
    Quote Originally Posted by gggb View Post
    When you get you box, update the softwa*e, using the correct one for your box(found in downloads)Then scan using the correct symbol rate for your provider. Sort out your channels using the above voxer link and you can save the channel order to your pc also.
    For more info read the red sticky here m8>Eurovox
    Or use autosort softwa*e, which will put channels in order.
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
