Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: 7000hd Firmware
    Aug 2009
    Runcorn
    Default 7000hd Firmware
    Hi all after spending loads of time messing with the fav's and deleting channels i dont want etc ive found a couple of things which i hope are just bugs with the firmware. Ive reflashed the box to be certain, if anyone can shed some light if there having any of the following,
    clicking the OK button sometimes freeze's the TV channel list (so a switch off from the box is the only option).
    When sorting Fav's out it puts channels in where u know you didnt put them ie. movies in sports.
    1080i setting stays the same but the aspect ratio is different from channel to channel.
    Any help here would be great
    Dunc
    Top Poster + Hob's Avatar
    Feb 2009
    Manchester
    For the moment (untill a newer firmware comes along)
    Re: Favs-
    When sorting your favs only choose favs 1234 & 8. Favs 5 6 & 7 have a fault. Name 1234 & 8 with your favorites (sport movies etc.
    Re the freeze- let the box boot before flying through the buttons.
    These problems will be ironed out in future fimware releases i'm sure.
    V.I.P. Member chic.'s Avatar
    Feb 2009
    glasgow
    my fav's are ok using the 12/3/09 firmware but i have read i few posts with that problem
    Feb 2009
    Manchester
    including 5 6& 7?
    Feb 2009
    glasgow
    Quote Originally Posted by Hob View Post
    including 5 6& 7?
    yes 5 6 and 7 are ok infact i dont have a problem with anything on this box only the crap epg but i can live with that
    Feb 2009
    Manchester
    Chic just tell me, when watching a channel what happens when you press exit?
    Feb 2009
    glasgow
    it brings up a limited epg with no info
    Feb 2009
    Manchester
    The info is on the second press of exit.
    I was just seeing if you had the pure new firmware and not a combination of the last two.
    So on the 56& 7 issue, you don't have the top 1/12 channels coming across from you previous fav.
    Feb 2009
    glasgow
    no i dont have any 5 6 7 issue i am using the 8/1/09 firmware with the 12/3/09 update and i dont get any programe info when i press exit a second time if i want to know what a programe is about i check it on my ex5000pvr in the bedroom
    DK Veteran lincsat's Avatar
    Jun 2008
    What area are you in? Pure NTL, ex C&W or Telewest?
    I have problems in Pure.
  11. #11
    Feb 2009
    glasgow
    Quote Originally Posted by lincsat View Post
    Hi m8 i am in pure and as i said above i only have a problem with epg then so dose everyone
  12. #12
    Aug 2009
    Runcorn
    Quote Originally Posted by chic. View Post
    Im ex CW, with a s**rview box u have to tell it what you are before you scan but i take it with a 7000hd it auto knows what you are as ive seen nothing saying ex c&w.
    Anyhow thank for the info on the other questions
    Dunc
  13. #13
    Feb 2009
    glasgow
    do you mean where you are if so then yes you need to scan on the symbol rate for your area
  14. #14
    Aug 2009
    Runcorn
    now im lost
    i scanned and recived channels, ok there is one channel i dont see now (arsenal) but no great loss heheh,
    so how do i check symbol rate (my area is ex c&w)
    sorry i sound like an idiot but ive only ever dealt with SV boxes before.
  15. #15
    Feb 2009
    glasgow
    if you have all the channels then you must have scaned the right symbol rate 6887 or 6952 press info btn twice and you will find it there
