Hello,
need help for Citroen berlingo 2011 year 1,6hdi edc17C10 DPF/Fap off and dtc P0460 , P1434 and P1435 turn off .
intflashmicro tc1797 original.rar
Thank you all for help.
Hello,
br.balazs (21st April, 2017)
HI
Dpf remove or fault will not help you if you have fault of the additve Pump, 1434, you have to remove it from bsi+ecu by configuration,and then apply dpf remove.
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
DjRomeoR (23rd September, 2016), hassan kasbaoui (18th April, 2021)
in engine ecu NO FUNCTION for dpf,fap, multiplexe addtive pump turn off :/// only in BSi are i turn off but same all this 3 faults came in :/
so maybe someone can do dpf off and this faulty codes turn off and maybe in cluster not be engine light. Car working good no limp mode only this 3 faults :/
If you remove from bsi is good, here DPF remove and Dtc
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
The regular check engine light or the one with !
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
when start engine - regular check engine light blinking > I try drive 5km but nothing same no faults and engine blinking :/ maybe bad turn off dtc or dtc?
Flashing-MIL1.gif< when you click on image you see how engine light blinking when i start engine.
you need additve off, not other way.
additve off allways in ECU, not in BSI
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
hello , yes this write me before ,but no > additive function in engine ecu , i search with lexia but no configuration function in this ecu only i can :
> gear box,dan blower, some sensor's reconfigurate ,but no multiplexe additive pump - fap function .
So how turn off additive in engine ecu ? me sent file but no result's (no faults engine light blinking) .
Dpf is tested 100%, i done alot of this, but if you have Additve pump fault P1434, it will always return, you have 2 ways only to solve as i said before,
1.you put second hand additve pump, and all be ok and dpf off work.
2.you need to configure very good , to remove fap funcation from bsi+ecu,
if you had just dpf fault the regular 1445, so no problem, in psa the problem come when the pump signaling to the bsi.
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
ok i think your file are good ,but how i must configurate ECU > in this ecu no functions about additive pump :/ I tryed old pump , and from other working car second hand pump ,same in engine are P1434-P1435 and i don't understand problem , i thinked it's bad dpf file ,but .... :/ and i can't find solution for this problem
can you give me tv with daigbox connected to the car ?
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
Dont exist such configuration for all kind of euro 5 psa cars !
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
DjRomeoR (24th September, 2016)
write dpf off file
disconect conector from aditiv pump
read dtc
send the file from car to tuners to remove dtc from this file
and rewrite the dpf off+ dtc off
job done...all be happy
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
why you speaking on something that sure you never did if you said "not exsit", P1434 will not work with dpf remove and dtc, and i done too many for i count them euro5, if you want next time you when you have car like that i can show you how "dont exsit such" will be exsit.
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
