    moky's Avatar
    Behind you
    Default Tprot or no please ?
    Hi all
    does this edc17cp14 have Tprot? or i can flash it by obd
    03L906022G SW 507614 (readed by obd)
    many thx !
    jakkeviet's Avatar
    Apr 2012
    hello can you tell more what is your tool?? org or clone??
    yeterday i write same ecu by opd and works fine my tool original galletto
  3. The Following User Says Thank You to jakkeviet For This Useful Post:
    moky (20th July, 2016)
    pandokrator's Avatar
    Oct 2008
    Eu.Gr
    need bdm readout for we now if have tprot.
    0xBB3C.
    if have you can remove it and done all via obd
    bR
    keep your friends close and your enemies closer
    Golden Section
    The Real ART
  5. The Following User Says Thank You to pandokrator For This Useful Post:
  6. #4
    moky's Avatar
    Behind you
    I have kess euro clone work 100% fine ..
    so sure no Tprot ?
    Jun 2013
    EU
    On partial obd read you can only guess by sw number if tprotected or not, need full bootmode dump to be sure. Normally 103739xxxx is not tprot if 103751xxxxx probably yes, for your 103750xxxx i would say no, but who knows.
  8. The Following User Says Thank You to morgano For This Useful Post:
    moky (21st July, 2016)
  9. #6
    Oct 2008
    Eu.Gr
    if you want to make a test by obd ,try write the mod file.
    if is TProt kess he give a message that ecu is Tuning Protection.
    if have TP then open ,read by bdm and post here dump.
    i remove TP for you
    bR
    Golden Section
    The Real ART
  10. The Following 2 Users Say Thank You to pandokrator For This Useful Post:
    moky (21st July, 2016), pablo1971 (1st November, 2016)
