Hi, i have lost long coding on VW Golf7 abs, can someone reconstruct it? I dont expect it to be free, just pm me.
Wednesday,20,July,2015,21:32:18:61290VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WVWZZZAUZEW296624 License Plate:
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CLHA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5517
Revision: 84H22---
Coding: 01110012032405092000
Shop #: WSC 99999 123 12345
ASAM Dataset: EV_ECM16TDI01104L906021M 002009
ROD: EV_ECM16TDI01104L906021AL.rod
VCID: 2F6DF53E76BD41663D9-807A
1 Fault Found:
17158 - Databus
U1123 00 [047] - Received Error Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 22173 km
Date: 2016.07.19
Time: 03:06:08
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 6025400000003B
Coding: 000000000000000000000000000000000000
Shop #: WSC 58299 001 1048576
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 7BF5116EF2456DC6C11-802E
13 Faults Found:
0071 - Rear Left Wheel Speed Sensor
C101C 4A [137] - Incorrect component(s) installed
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Date: 2016.07.19
Time: 03:03:32
0087 - Rear Right Wheel Speed Sensor
C101D 4A [137] - Incorrect component(s) installed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Date: 2016.07.19
Time: 03:03:32
8196 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Date: 2016.07.19
Time: 03:03:32
8278 - Control Module Incorrectly Coded
U1014 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Date: 2016.07.19
Time: 03:03:32
8291 - Databus
U1123 00 [008] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 127
Mileage: 22173 km
Date: 2016.07.19
Time: 03:04:41
8299 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Date: 2016.07.19
Time: 03:03:32
8309 - Engine Control Module Incorrectly Coded
P1612 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 87
Date: 2016.07.19
Time: 03:03:32
8351 - Databus
U1122 00 [009] - Implausible Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Date: 2016.07.19
Time: 03:03:32
8356 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Date: 2016.07.19
Time: 03:03:32
8368 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 87
Mileage: 22173 km
Date: 2016.07.19
Time: 03:03:47
16390 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 22173 km
Date: 2016.07.19
Time: 03:03:50
32992 - Control Module for Electric Parking Brake
C10E2 F0 [137] - RPM Sensor Implausble Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Date: 2016.07.19
Time: 03:03:32
32994 - Control Module for Electric Parking Brake
C10E2 F0 [009] - RPM Sensor Implausble Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Date: 2016.07.19
Time: 03:03:32
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 5G0 907 426 J HW: 5G0 907 426 J
Component: AC Manuell H01 0503
Revision: 00001K06
Coding: 00020104202100001000000000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ACManueBHBVW37X 002017
ROD: EV_ACManueBHBVW37X_VW37.rod
VCID: 326BFC4A658F6C8E527-8067
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
No fault code found.
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 AC HW: 5Q0 937 084 AC
Component: BCM MQBAB M H16 0124
Serial number: 00011403100176
Coding: 00000842C241005B4FE44000000403081000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_VW37.rod
VCID: 79F90B66F8795FD6D3D-802C
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A
Component: WWS 121111 042 0551
Serial number: 121208023236
Coding: 0E4DD5
1 Fault Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 87
Mileage: 1048574 km
Date: 2000.00.00
Time: 00:00:00
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R01YBU/
Coding: 98CCC000000000005C0000CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 408FA682DB23CE1ED43-8015
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 000 201 13
Component: SideSensor_Df 001 0887
Serial number: 35767000000EF41C7C07
Coding: 2D2D2D
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 000 201 13
Component: SideSensor_Pf 001 0887
Serial number: 358670000003A2745C0T
Coding: 2D2D2D
Crash sensor for side airbag; rear driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 400 301 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502BD0D5D605B1CQ
Coding: 2D2D2D
Crash sensor for side airbag; rear passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 400 201 13
Component: SideSensor_Pr 001 6149
Serial number: 3526502BB0D5D603E2CR
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 401 512 12
Component: FrontSensor_D 001 6149
Serial number: 3556502A90CD5EC0F18$
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AM HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 07011308490408
Coding: 1704
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB.rod
VCID: 8109E38610A987161BD-80D4
Address 17: Instruments (J285) Labels: None
Part No SW: 5G0 920 961 A HW: 5G0 920 961 A
Component: KOMBI 204 3390
Coding: 27A41A002780260001882A01040000
Shop #: WSC 03020 425 00000
ASAM Dataset: EV_DashBoardJCIMQBAB 008011
ROD: EV_DashBoardJCIMQBAB.rod
VCID: 285F1E225353165EFC3-807D
3 Faults Found:
16776960 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 22173 km
Date: 2016.07.19
Time: 03:03:31
16776961 - Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 22173 km
Date: 2016.07.19
Time: 03:03:31
16777020 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 22173 km
Date: 2016.07.19
Time: 03:03:34
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 D HW: 5Q0 907 530 D
Component: GW MQB Low 120 1109
Revision: -------- Serial number: 0000237325
Coding: 030000040B087300EF000048080F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_VW37.rod
Generator:
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 3977378601
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 5Q0 959 393 A HW: 5Q0 959 393
Component: TSG FS 012 0006
Serial number: 09121200090085
Coding: 003003208000040000001000
ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 3D71DF76ACD1A3F6BF5-8068
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000000524461
Coding: 010000
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB.rod
2 Faults Found:
19716 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 6
Reset counter: 87
Mileage: 22173 km
Date: 2016.07.19
Time: 03:03:34
20228 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 87
Mileage: 22173 km
Date: 2016.07.19
Time: 03:03:34
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 5Q0 959 392 A HW: 5Q0 959 392
Component: TSG BFS 012 0006
Serial number: 01121200011406
Coding: 003001208000040000801000
ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3C77D272B7CBAAFE88B-8069
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000000497095
Coding: 090000
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5G0 035 867 HW: 5G0 035 867
Component: MU-E--ER 615 5561
Serial number: 20111200010132
Coding: 02730000FF0000004011000100000000000000040000010000
ASAM Dataset: EV_MUEnt4CLGE 001025
ROD: EV_MUEnt4CLGE_VW37.rod
VCID: E9D9DB2608D96F56A3D-80BC
End ---------------------------------------------------------------------
