Page 13 of 15 FirstFirst ... 389101112131415 LastLast
Results 181 to 195 of 212
  1. #181
    DK Veteran NICETOBNICE's Avatar
    Nov 2011
    hi Cunny I have new drive just waiting to be flashed its the last possible thing I will attempt before trying to jtag the xbox.i just wanted to know from a man who knows' what stock firmware I should flash on the new drive my current dashboard is 2.0.16203.0 and I have checked the power plug and can confirm its a falcon
    Thanks mate
  2. #182
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by NICETOBNICE View Post
    Thanks mate
    Is your drive a liteon?
    If it is your firmwate is 02551 and its in the latest fw packs and beeen avail for years
  3. #183
    Nov 2011
    Quote Originally Posted by cunny View Post
    yes mate its a liteon not sure what you meant there can you clarify ?
  4. #184
    cunny's Avatar
    Jan 2009
    The Shoutbox
    If you find latest fw pack on here it will contain the fw you need.
    Or if you have it downloaded look in phat liteon post 146 folder
    Sent from my GT-P5110 using Tapatalk HD
  5. #185
    Nov 2011
    Thanks mate
    so if I flash this firmware to my drive orig-02510C-1c000 do I have to sign into live first before I flash it with LTPlus-0251-v3.0 ?
  6. #186
    cunny's Avatar
    Jan 2009
    The Shoutbox
    If you flash stock fw to your dtive, you will be able to update to the latest dash fine. If it all plays fine then you will be able to flash to LT3.0 knowing your key was correct
  7. #187
    Nov 2011
    Thanks mate do i still need to enter the key when i flash it to stock
  8. #188
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Yes you will as each consoles key is deffefent
    Sent from my GT-I9305 using Tapatalk 4
  9. #189
    Nov 2011
    Cunny sorry mate but just noticed my newly installed xp o/s is having difficulty seeing the key
    when i open key db there is nothing shown but when i tried to click a button it says exception is this a registry problem how is this resolved mate ?
  10. #190
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Not sure ive seen that before. All .net framework installed?
  11. #191
    Nov 2011
    Yes all framework updates are installed
    Think its the key database registry file thats no longer there so question is how the hell do i repair it
    Theres lots of videos explaining how to backup the key db reg file but what if you havent ?
  12. #192
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Im guessing you not got your key no more????
  13. #193
    Nov 2011
    Yes got my key but should it be in the registry database ?
    Dont think my key works to be honest mate reckon its corupt you no all the shit i've been through
  14. #194
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Just reload your dummy.bin an it should be ok. I still have the 1 u sent me
  15. #195
    Nov 2011
    Load of shit mate have a look at this mate it still wont recognise my key
    JungleFlasher 0.1.92 Beta (304)
    Session Started Wed Sep 04 20:43:26 2013
    This is a 32 bit process running on a 32 bit CPU
    portio32.sys Driver Installed
    portio32.sys Driver Started, thanks Schtrom !
    Found 8 I/O Ports.
    Found 4 windows drives C: D: E: F:
    Found 3 CD/DVD drives D: E: F:
    Loading firmware file C:\Documents and Settings\Stanley\Desktop\my liteon backup\Identify.bin
    MD5 hash: 2eaafa99e370b803814a952b34f04a15
    Parse Failed !
    Loading firmware file C:\Documents and Settings\Stanley\Desktop\my liteon backup\Inquiry.bin
    MD5 hash: 03c32557eb74da9a160aedb47b31a0c7
    Parse Failed !
    Loading firmware file C:\Documents and Settings\Stanley\Desktop\my liteon backup\Key.bin
    MD5 hash: 6cd0f2ee940527f61873b13748402315
    Parse Failed !
    Loading firmware file C:\Documents and Settings\Stanley\Desktop\my liteon backup\Lite_CFW.bin
    MD5 hash: ea4dcccd71ff5607f602cc2d4bc56292
    Drive key @ n/a ACF9AC5A1736D9266F92AC0D3AACC371
    Firmware Osig: [PLDS DG-16D2S 0251]
    Firmware is: LT-Plus 3.0
    Loading firmware file C:\Documents and Settings\Stanley\Desktop\Latest_iXtreme_and_Stock_ Firmware_Pack\Stock firmware\LiteOn (Phat)\LiteOn_Post_13141\orig-02510C-1c000.bin
    MD5 hash: e7e0f802769fd80329784ca4b512f1a9
    Drive key @ n/a FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    Firmware is: Stock
    Spoofing Target
    DVD Key copied to target
    Target is LT - ID strings not copied to Target
    Serial data already matches
    Target rev is LT 02510C, serial info not copied
    Drive is Lite-On..
    Getting Status from port 0xA400
    Invalid Status 0x50
    Sending Lite-On-Erase request to port 0xA400
    Drive returned Status 0x72
    Manufacturer ID: 0x0
    Device ID: 0x0
    Flash Name: Unknown type
    Flash Size: n/a
    Drive returned Status 0x0
    Serial flash found with Status 0x72
    Manufacturer ID: 0xC2
    Device ID: 0x11
    Flash Name: MXIC(MX25L2005)
    Flash Size: 262144 bytes
    SPi flash found with Status 0x72
    Sending Chip Erase to Port 0xA400
    Erasing:
    Writing target buffer to flash
    Writing Bank 0: ................
    Writing Bank 1: ................
    Writing Bank 2: ................
    Writing Bank 3: ................
    Flash Verification Test !
    Reading Bank 0: ................
    Reading Bank 1: ................
    Reading Bank 2: ................
    Reading Bank 3: ................
    Write verified OK !
    Sending Vendor Outro to port 0xA400
    Drive is Lite-On..
    Drive type Un-determined
    Drive is Lite-On..
