I assume so, as LT is supposed to be as close as C4E can get it, then I would imagine that you would get it if its been flashed before, regardless of FW
I am awaiting delivery of a Probe V3 and a X360 but when they arrive, i will be trying them out
This is a step by step guide for the 9 series with the X360 done by Ubergeek over on TX so all credit to him
Code:http://team-xecuter.com/forums/showthread.php?t=60930
thats an excellent tut thanks all, quick query, could i use my old probe for the original liteon's and power cycle as i've always done, by pulling out white power cable at back of drive, i have never had the ck b4
You can convert a Ck Probe to a PMT (V3 Probe) but your best off with a CK3 Lite or Pro, just makes it easier for powering drives and poweer cycling them
I just brought XBOX360 kinnect (slim). There is any flashing instructions for this new XBOX 360 kinnect.
i just got my xbox 360 modded today. i am trying to figure out how to copy a 360 game someone please help i have googled it but every website says something different
cna i flash an xbox360 elite with a liteon drive with out soldering?
Andy
Hi cunny, need ur pro assistance sir...i'm having problem playing the latest backup games such as the need for speed hot pursuit having stuck at logo xbox360...the only game i can play so far is modern warfare 2 with kind of bootdisc stated ver 1.6..etc..etc...i have check thru ur guide that my xbox is the phat with kind of yellow cable when i verify it and i assume that it is confirm DG-16D2S..How do i upgrade the firmware to the latest version so that it no more longer using a bootdisc to play or whichever is easy ...no idea at all since this xbox set was pass down to me by my fren which he bought from the shop....
You will need to pull key off drive. Update dashboard and flash to 1.9 if you want to use live.
You could just reflash drive to lt1.1. Again follow the tuts here on team xecuter and the jungleflasher guide.
I have done a few boxes this week and updated dash and firmware this is so they won't get flashed again when dashboard 146 comes onto games and flashes their drives.
If you can't do the upgrade then I am sure someone local to you.
The game issue sounds like ap25 checks
Sent from my GT-I9000 using Tapatalk
thnx cunny i will do it by myself..any assist can i get direct from u if not sure....this case i need to purchase the probe as u say right from team axecuter....thnx again
Quick (noobie) question..
was looking to get a premodded slim and someone has one available which is has the new unlock PCB+ installed.
Is this the latest one to get?
I have read that once you update the firmware, it is locked so it cannot be overwritten unless you unlock it?
Thanks for your help.
The TX PCB allows YOU to enable/disable the WP on the PCB
