How can you desable throtle valve? How will the car accelerate?
Throttle valve is malfunctioning, can it be disabled completly (disconnected) like egr?
Car is in limp revs up to 3300.
dtc: P2111 - Motorised throttle
Car is alfa 147
1037386724.zip
Try this file. Don't disconnect throttle
Try and report:
WinOLS (11573.rar
donesko (24th July, 2016)
What's wrong with disable throttle valve on a diesel?
While you are at it ,might as well disable one or two injectors...
A failure will not appear till a unit has passed final inspection
throttle valve on jtd is only used to smoothy turn off car, no problem without it, on old cars you can just unplug vacum
No problem make disable throttle actuator on most diesel cars.
Only problem is after - one protection less
Stopping engine was much less comfortable
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
rideon (25th July, 2016)
Who cares about dual mass flywheel anyway.. getting cheaper lately.. and is a 5 minutes job ..
ilkovelichkov (4th June, 2020)
