Some are told this can read Smoke but I don't have idea. How ever check this link you can get some ideas
https://iprogplus.com/goods-from-use...-scripts-r183/
Sent from my C5502 using Tapatalk
I found in cluster of Hyundai Sonata 2015 an MCU named MB91F067CS which i thought it is FUJITSU but actually the name is SPANSION.
Does any one know if it is to be read like FUJITSU ? Has any one used SMOK to read this MCU ?
HYUNDAI SANTA-FE.jpgSantaFe.jpgSPANSION MB91F067CS.jpgHYUNDAI SANTA-FE 2015 with SPANSION MB91F067CS.jpg
junmab (27th July, 2016)
Thanks mate,
I looked at the link you sent, and noticed they are talking about MB91F067BS while the MCU i have in the Sanatfe is MB91F067CS.
I don't know if the letter "C" is a dramatic change from the letter "B", but the fact that the MCU is labeled as it was made by SPANSION
and not by FUJITSU worries me.
Its Fujitsu 100%
Supported by good tools...
Want name of tool contact me by PM.
HONDA CITY - FUJITSU MB91F061
HONDA FIT - FUJITSU MB91F061
HONDA JAZZ - FUJITSU MB91F061
HONDA PILOT - FUJITSU MB91F061
HONDA VEZEL - FUJITSU MB91F061BS
HYUNDAI ELANTRA GT 2016 - FUJITSU MB91F062BS
HYUNDAI I30 - FUJITSU MB91F062BS
HYUNDAI I40 - FUJITSU MB91F062BS
HYUNDAI SANTA FE - FUJITSU MB91F062CS
HYUNDAI SANTA FE - FUJITSU MB91F067CS
HYUNDAI SONATA - FUJITSU MB91F062BS
HYUNDAI SONATA HYBRID - FUJITSU MB91F062BS
KIA CARNIVAL - FUJITSU MB91F067
KIA CERATO - FUJITSU MB91F067
KIA PICANTO - FUJITSU MB91F061BS
KIA SEDONA - FUJITSU MB91F061BS
KIA SORENTO - FUJITSU MB91F067
SUZUKI JIMNY - FUJITSU MB91F061
Live by the rules and die by the rules...
Thank before you die...
See this info, it will help you understand why its written Spansion and not Fujitsu...
http://www.fujitsu.com/global/about/...3/0430-02.html
Berubeg (30th August, 2016), junmab (27th July, 2016), pongsky (26th July, 2016), rtbdiagnostic (17th September, 2021)
for cerato 2018 mb91f067cs CG 100 PROG ok 100% otion kia K3 MB91F063S oll ok
what tool you used?
I have Hyundai I40 prog ok ,all work fine by OBD2,but mileage is sttoped,you drive a lot km ,but km allways same ,stop,big problem.With Smok Tool.
If the mileage is not going up after changing by OBD you can change it using Jtag and it should start increasing after driving about 10 - 20 kms.
This works every time with the Picanto .
ATRON (5th December, 2019)
Friend, it worked well for you, I have no problems later with cg100 choosing that model
Hola porfavor tendras el dump del kia cerato 2017 memoria MB91F067CS se me corrumpio la informacion porfavor apoyame
