Hyundai Santafe 2015
Results 1 to 8 of 8
    Dec 2010
    149
    Downloads
    Uploads
    Default Hyundai Santafe 2015
    I found in cluster of Hyundai Sonata 2015 an MCU named MB91F067CS which i thought it is FUJITSU but actually the name is SPANSION.
    Does any one know if it is to be read like FUJITSU ? Has any one used SMOK to read this MCU ?
    HYUNDAI SANTA-FE.jpgSantaFe.jpgSPANSION MB91F067CS.jpgHYUNDAI SANTA-FE 2015 with SPANSION MB91F067CS.jpg
    Brayn's Avatar
    Oct 2015
    Colombo
    329
    Downloads
    15
    Uploads
    Some are told this can read Smoke but I don't have idea. How ever check this link you can get some ideas
    https://iprogplus.com/goods-from-use...-scripts-r183/
    Sent from my C5502 using Tapatalk
    Mileage Correction , SRS Crash Clear , DPF Remove
  3. The Following User Says Thank You to Brayn For This Useful Post:
    junmab (27th July, 2016)
    Dec 2010
    149
    Downloads
    Uploads
    Thanks mate,
    I looked at the link you sent, and noticed they are talking about MB91F067BS while the MCU i have in the Sanatfe is MB91F067CS.
    I don't know if the letter "C" is a dramatic change from the letter "B", but the fact that the MCU is labeled as it was made by SPANSION
    and not by FUJITSU worries me.
    Landetos's Avatar
    Mar 2013
    Inside EnigmaTool
    225
    Downloads
    3
    Uploads
    Quote Originally Posted by junmab View Post
    Its Fujitsu 100%
    Supported by good tools...
    Want name of tool contact me by PM.
    HONDA CITY - FUJITSU MB91F061
    HONDA FIT - FUJITSU MB91F061
    HONDA JAZZ - FUJITSU MB91F061
    HONDA PILOT - FUJITSU MB91F061
    HONDA VEZEL - FUJITSU MB91F061BS
    HYUNDAI ELANTRA GT 2016 - FUJITSU MB91F062BS
    HYUNDAI I30 - FUJITSU MB91F062BS
    HYUNDAI I40 - FUJITSU MB91F062BS
    HYUNDAI SANTA FE - FUJITSU MB91F062CS
    HYUNDAI SANTA FE - FUJITSU MB91F067CS
    HYUNDAI SONATA - FUJITSU MB91F062BS
    HYUNDAI SONATA HYBRID - FUJITSU MB91F062BS
    KIA CARNIVAL - FUJITSU MB91F067
    KIA CERATO - FUJITSU MB91F067
    KIA PICANTO - FUJITSU MB91F061BS
    KIA SEDONA - FUJITSU MB91F061BS
    KIA SORENTO - FUJITSU MB91F067
    SUZUKI JIMNY - FUJITSU MB91F061
    Live by the rules and die by the rules...
    Thank before you die...
  6. The Following 4 Users Say Thank You to Landetos For This Useful Post:
    cklair (2nd August, 2017),JammerOne (16th June, 2017),junmab (27th July, 2016),pongsky (26th July, 2016)
  7. #5
    Landetos's Avatar
    Mar 2013
    Inside EnigmaTool
    225
    Downloads
    3
    Uploads
    See this info, it will help you understand why its written Spansion and not Fujitsu...
    http://www.fujitsu.com/global/about/...3/0430-02.html
  8. The Following 3 Users Say Thank You to Landetos For This Useful Post:
    Berubeg (30th August, 2016),junmab (27th July, 2016),pongsky (26th July, 2016)
  9. #6
    May 2017
    18
    Downloads
    10
    Uploads
    for cerato 2018 mb91f067cs CG 100 PROG ok 100% otion kia K3 MB91F063S oll ok
  10. #7
    Jan 2016
    16
    Downloads
    Uploads
    what tool you used?
    I have Hyundai I40 prog ok ,all work fine by OBD2,but mileage is sttoped,you drive a lot km ,but km allways same ,stop,big problem.With Smok Tool.
  11. #8
    Jul 2010
    Ireland
    31
    Downloads
    17
    Uploads
    If the mileage is not going up after changing by OBD you can change it using Jtag and it should start increasing after driving about 10 - 20 kms.
    This works every time with the Picanto .
  12. The Following User Says Thank You to frontpager For This Useful Post:
    ATRON (Yesterday)
