Results 1 to 15 of 25
    WinWoj's Avatar
    Jan 2012
    ECU City
    Default Mercedes ML W163 2004 key programming after AAM and CDI ecu replace...
    Hello mates. That W163 '2004 have EAM with DAS, AAM and CDI ecu. I bought car without CDI ecu and AAM. I run car using emulator, bought AAM and working. But now I want to use key and remote, also electric windows and mirrors, because never worked. So, I opened EAM (HC05 1D69J), DAS (HC05 1D69J), CDI (5P08) and AAM (HC705 0G47V). In key is such PCF. What I should to read to attach here, to complete coding procedure using SD? I can read transponder using china carprog, such data is visible...
    CDI: 0 281 010 796
    AAM: 163 545 00 16
    EAM: 163 545 90 32
    DAS: 163 545 28 32
    I will be very gratefull for help.
    Best Regards.
    workshop
    for transponder generate,read DAS(FBS)
    after start,you can remote learning
    hold close button and put 5 x open
  3. The Following User Says Thank You to mercis For This Useful Post:
    WinWoj (27th July, 2016)
    Must put CDI to virgin state (modify eeprom same you have did before put emulator) , carprog will programm key , but you need virgin PCF7930AS or PCF7935AS , old transponder from key you can put to trash . After use Star to personalize CDI and programm remote
  5. The Following User Says Thank You to Saulyss For This Useful Post:
  6. #4
    WinWoj's Avatar
    Jan 2012
    ECU City
    carprog which i using do w163 to 2000 year, after 2000 not. so when I will make cdi eeprom to virgin state and use new pcf transponder, all the rest steps can I make using Star?
    workshop
    after 2000,FBS (das)
  8. #6
    Sure carprog doesnt do ? , if not then AVDI , or manually read motorola , and do key with tango or etc. tool . As STAR will not programm blank transponder .
  9. #7
    WinWoj's Avatar
    Jan 2012
    ECU City
    Hello, There is a progress. I read dumps HC705x32's from AAM and DAD(FBS). I have also new PCF transponder ready to write. What Should I do first to start car? AAM was bought new one (used from another ML), DAS (FBS) is orginal, but engine control module (CDI) is used, till now car worked using emulator, but now I want to have working immo. Please help.
    03-aam-w163-hc705x32.rar
    11-das-w163-hc705x32.rar
  10. The Following User Says Thank You to WinWoj For This Useful Post:
    br.balazs (4th March, 2017)
  11. #8
    WinWoj's Avatar
    Jan 2012
    ECU City
    Mates, please generate key from EAM (file DAS-FBS) attached above... i haven't tool to generate mb eam based key, only carprog to write data to transponder....
  12. #9
    volismb's Avatar
    Feb 2016
    Quote Originally Posted by WinWoj View Post
    Here your keys
  13. The Following 4 Users Say Thank You to volismb For This Useful Post:
    br.balazs (4th March, 2017), Col19 (24th November, 2020), WinWoj (2nd September, 2016), wsc (12th September, 2016)
  14. #10
    WinWoj's Avatar
    Jan 2012
    ECU City
    Hello guys, I have AD900 to program transponder but I can't find w163 in Mercedes Benz list, only such ID numbers or something another. What to choose to put dump to PCF7935 I bought for it?
  15. #11
    WinWoj's Avatar
    Jan 2012
    ECU City
    I see no w163 available to use with AD900... In list is ml320 - type "33 rolling code", and what does it mean? No way to open key dump and write it to transponder using this tool?
  16. #12
    Dec 2015
    Lithuania
    with which device generated your keys (v1 or v2)? Can I see your password?
    Thank you
    Quote Originally Posted by volismb View Post
    Here your keys
  17. #13
    WinWoj's Avatar
    Jan 2012
    ECU City
    Hello. I still have a problem with this car. I mean Mercedes ML W163 2004 EAM/DAS based.
    I read EAM dump.
    For car starting I use cdi2 emullator.
    Now I desolder emulator, bought gambit key maker and write key1 (used) from my EAM dump.
    Switched ignition on using new, 7935AS transponder written as key1 using gambit and 'Start Error' message in dash.
    So, What i do wrong? Should I modify cdi eeprom as virgine, when I stop using emulator and start using transponder key?
    Please help.
  18. #14
    WinWoj's Avatar
    Jan 2012
    ECU City
    I used virginized dump for ECU, but still 'Start Error'.
    No dtc, but das 'not personalized and no activated' in cdi ecu.
    I DAS:
    - key in ignition : -----
    - transponder learned : yes
    - transponder is interlocked: yes
    - drive authorisation status: through brake switch (SA)
    what is wrong? after emulator using, i write virgine dump to cdi ecu and write new pcf7935as using gambit special function 'ML EAM based' key1...
  19. #15
    Sep 2010
    I DAS:
    ok after program keys u.r work in das and eam is finsh
    naw usay u virginized dump for ECU still need do sync eam to ecu by mb star tool or anther tool
    then car will start normally
    in the way please can u sher wher u pay emoulatore
    i need pay its
    regards
  20. The Following User Says Thank You to large12390 For This Useful Post:
    WinWoj (3rd July, 2017)
