Page 103 of 127 FirstFirst ... 353939899100101102103104105106107108113 ... LastLast
Results 1,531 to 1,545 of 1900
  1. #1531
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by sleepyrz View Post
    Nope not possible
    And i mean that in both directions
    No im not gonna stop poking them
    No its not possible for them to fix these issues
    They dont have the capability anymore.........
    They only have app developers
    Notice there is a robust and working and updated custom keytool for the dolphin.......
    Using an app
    Custom key tool never even got finished 4 years ago
    Half of it doesnt even work.......
    Hmmmmmm
    Think about it
    i'm jus guessing. They have only limited resources (both financial and human) and they are not leading the market they are reacting the market... Wrong management thats all they don't have clear vision, path whatever you call it they are simply using on wrong ways the resources. But again i'm just guessing
  2. #1532
    Jan 2017
    USA ����
    Quote Originally Posted by jodge View Post
    limited resources? they manufacture in china for pennies...........
    they sell thousands of vvdi2 vvdi mb vvdi prog and dolphin and condors and duplicators and useless m4 jaws
    they sell for thousands of dollars
    chinese labor ? expensive?
    not limited just stupid to see what needs to be done
    if the condor xc-mini had a fully working custom key tool or even fully functional bluetooth so it could connect to the apps custom key tool it would literally be a 3-4 times better of a machine
    imagine having the correct cutting profile whenever you needed it
    on the app's custom key tool for the dolphin there is a place you can make custom key files and share them with the rest of the community
  3. #1533
    Mar 2009
    Still doesnt do dimple keys either. Advertising says it does. Havent seen an option or even a custom key tool for it, so we could do it ourrselves. I asked samic about this, and the not very good existing custom key tool at the MLA show last year, and he said it would get better. It hasnt. No changes. I told him the updates with no text saying what was different, so we could choose when to update, why do that ? He didnt have a good reason. I get the feeling its no longer a supported product.
    Although I have one of these machines, I'm disappointed its not better supported. With much less effort than it takes to bring out a new machine they could have made the existing machines so much better.
    I wont buy another key cutting machine from them again as a result of this lack of support.
  4. #1534
    Dec 2019
    Was trying to duplicate some keys today
    was stunned how poor database base is
    couldn't find most of the keys
    is there solution for it?
    If i add custom key will it appear in duplicate key section?
  5. #1535
    Jan 2017
    USA ����
    Quote Originally Posted by Lancolm View Post
    ugh seriously people GET INSTACODE LIVE
    quit screwing around with that stock garbage on the machine
  6. #1536
    Perry I have just brought a dolphin and notice the HU162T cuts are different to instacode and also different from a video I seen for the condor mini?
  7. #1537
    Mar 2015
    UA
    Hey. Renault Master key as pictured. What niches to use for decoding? VA2T does not fit? Can a dolphin cut a key correctly? Thanks.
    What is the need lischi- decoder is needed for this key?
  8. #1538
    Dec 2010
    Nottingham
    the correct lishi pick and decoder is the VA6 4 lifter tool . if doesnt insert fully in the lock then its bad cutting ,
  9. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    MVVL (21st January, 2020)
  10. #1539
    Jan 2017
    USA ����
    Quote Originally Posted by madaxe View Post
    Exactly
    They been putting out the same exact garbage machine for over seven years and haven't changed a single damn thing it still has all the same issues all the same problems and none of them ever got fixed
    a fully working custom key tool would fix nearly all of their problems
  11. #1540
    szengen's Avatar
    Jan 2017
    you are not from the first league, you demand something, demand from silca, if not catch butterflies
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
  12. #1541
    Apr 2016
    North Yorkshire
    New Dolphin out of the box, all latest software and app updated, clamp calibration successful but everytime I go to key calibration or cut a key, just about to start milling and the machine turns itself off and on again quickly, loosing Bluetooth connection each time, so won't calibrate a key or cut a key.
    Tried a key de-code and that works 100%. Any idea what is going on ??
  13. #1542
    Jan 2017
    USA ����
    Your machine is broken
    Or you didnt charge it
    Try with wall adapter plugged in?
  14. #1543
    Apr 2016
    North Yorkshire
    Battery level says 100% butvas soon as I disconnect the mains it shuts down. I have checked, and it does have a battery fitted !
    Brand new out of the box as well.
  15. #1544
    Jan 2019
    So is the Dophin not good? I wanted to buy this..
    Is the CGDI Godzilla any good?
  16. #1545
    Jan 2017
    USA ����
    Sadly dolphin is best they got at the moment............
    Get kukai alfa at this point its soooooooo much better
