Page 104 of 127 FirstFirst ... 4549499100101102103104105106107108109114 ... LastLast
Results 1,546 to 1,560 of 1900
  1. #1546
    Jun 2013
    Quote Originally Posted by Focus66 View Post
    Battery level says 100% butvas soon as I disconnect the mains it shuts down. I have checked, and it does have a battery fitted !
    Brand new out of the box as well.
    Contact support.
    This is not, how this machine usually works.
    No problems with battery, it hold the voltage usually quite good.
    But better when it was new.
    I hope there is a battery swap program in the future. (If the machine is still supported )
    By the way, congratulations all members with the Brexit, I have waited many years for this.
    The Champagne bottle is bought in and opened, just for UK and this event.
    Full support for Great Britannia, and the new path of the future.
  2. #1547
    Jan 2019
    Quote Originally Posted by sleepyrz View Post
    Sadly dolphin is best they got at the moment............
    Get kukai alfa at this point its soooooooo much better
    Dolphin is best in regards to?
    I'm looking for good entry level key cutter I can use for AKL
    Need something to get me started and see if this is a good path to go down.
  3. #1548
    Jun 2013
    Quote Originally Posted by crankycarl View Post
    Its a good backup number two.
    It saved me today. When number one went down. During a battery drain.
    Of a big huge 12V battery AGM, which I forgot remove the clamp.
    Which I usually do after a cut.
    Cut 101de,64de and 92coAKL as a backup this afternoon.
    And made job completed.
    Edit:
    But number 1 which have very few updates. And 2 which have a lot of updates, failed on FEM key.
    Now I understand why I never could do the AKL, after reading the lock. The cuts are to wide on both machines.
    I need to update to the latest firmware on the Dolp. Maybe number 2 is getting better.
    Had to use manual machine.
    Did the job perfectly.
  4. The Following User Says Thank You to Weasel3 For This Useful Post:
    crankycarl (1st February, 2020)
  5. #1549
    Jan 2017
    USA ����
    Best you can get from xhorse.......
    Still not great though
    Kukai alfa/lock labs triton way way way way way better
  6. #1550
    Oct 2016
    Scotland
    Anyone able to confirm the code of this HU64 by eye? I'm not with the car just now, and i've never had great luck with the XC mini decoding the key, so trying to plan ahead to minimise any problems. I think it may be 2424355312, but wanted to check before i cut it.
    Also, does anyone have any yips about using the XC mini to properly decode and cut HU64 blades. Surely i must just be doing something silly that it's not working correctly.
    Thanks in advance
  7. #1551
    Disregard. Cuts correct
  8. The Following User Says Thank You to dmp For This Useful Post:
    WRX 14 (3rd February, 2020)
  9. #1552
    Jun 2013
    Dolph
    Decode key.
    Push button OK decoding.
    And accidently at the same time hit the numbers of bitting.
    So I change the number, without knowing it.
    Cut key. And of course its wrong.
    Scratch my head a little bit, bittings by eyes.
    Cut OK!
    Change blade to new style. To make a new cut.
    And I do the same trick again, when touching screen to say OK.
    Never done it before.
    The OK button should not be in the same area as the bitting numbers.
    But I guess this is something to do with the various of screens and sizes.
    Maybe not a problem for other users.
    But if it is possible.
    It would be nice to move the OK button after decoded right.
    So it wouldn't happen again.
  10. #1553
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    After last update Honda cutting key fail, the key neck is not cut,(i think axis X - Z are inverter in this area) then the key not go to finish of the lock cylinder. XC-Mini Km03 Ver. 6.0.6
  11. #1554
    castin's Avatar
    Oct 2015
    Quote Originally Posted by ruffles1986 View Post
    I confirm, I had to cut the last position on the manual machine.
  12. #1555
    Jul 2018
    CHINA
    hi , i think your machine has issue , can you add my skype what you can see it in my profile , i can help with you about that, the battery seems not good ,
  13. #1556
    Jul 2018
    CHINA
    Quote Originally Posted by castin View Post
    the version 6.0.6 seems has some issue , pls back to old version to see if you have the issue , and now ,china is in the virus situation , the work process is slow down , but xhorse will solve the problem asap
  14. #1557
    Jul 2018
    CHINA
    Quote Originally Posted by paul_12345 View Post
    Perry I have just brought a dolphin and notice the HU162T cuts are different to instacode and also different from a video I seen for the condor mini?
    which option you mean, in the hu162t , it has 3 types of cuts , you need to confirm which one is yours
  15. #1558
    Top Poster kristikapa's Avatar
    Anyone can share some feedback about CGDI Godzilla? Specs are promising.
  16. #1559
    Apr 2016
    North Yorkshire
    After my earlier post re problems with my Dolphin out of the box, I returned it to my UK supplier who couldn't fix it, they have swopped it for a new one which now works perfect.
  17. The Following User Says Thank You to Focus66 For This Useful Post:
    Weasel3 (12th February, 2020)
  18. #1560
    Jan 2019
    Quote Originally Posted by kristikapa View Post
    curious as well
