Page 106 of 129 FirstFirst ... 65696101102103104105106107108109110111116 ... LastLast
Results 1,576 to 1,590 of 1932
  1. #1576
    castin's Avatar
    Oct 2015
    Quote Originally Posted by szengen View Post
    I dismantled the lock for Renault trafic 2015, original wafers 831334, on the machine as va6 flips 2 latches,
    831334-ORYG.
    831334-CUT CONDOR ERROR
    83Q331-SUPER CONDOR
  2. #1577
    didi_du_93000's Avatar
    France Paris
    Dolphin feedback...
    Va6 va2: bad decoding, I have also try to make decoding by "universal duplicate" menu but probe is broken during the decoding.
    Hu83: bad Cuting in all situation (akl and copy key)
    Vac102: good decoding but bad cutting.
    See picture.
    I think it's beter to take another machine...
    With Tapatalk
  3. #1578
    rob h's Avatar
    May 2011
    Always brush key or scrape edges, before decoding.
    And some new keys come with yellow color coat.
    These i scrape light on the edge where the probe connects.
    There are some bugs, that should have been fixed long time ago.
    Va2 va6 cleaned well, duplication is helpfull,
    However, some Keys are to worn to duplicaten.
    Hu101 Ford, very often only visual decoding possible.
    And use the correct size cutter.
    Some Keys, like hu64, machine Will give a 1.5mm cutter recomandation.
    Va2 va6 2.0mm is best.
    2.5mm Will leave jagged track, and 1.5mm to narrow can bend shims in the lock
  4. The Following User Says Thank You to rob h For This Useful Post:
    fred77 (17th May, 2020)
  5. #1579
    szengen's Avatar
    Jan 2017
    xx?xx? VA6 error in 2 pawls mirror image
    83 1 33 4 -ORYG.
    83 Q 33 1-SUPER CONDOR
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
  6. #1580
    France Paris
    83 1 33 4 -ORYG.
    Can you explain?
    With Tapatalk
  7. #1581
    szengen's Avatar
    Jan 2017
    Default error 2 latches,
    VA6.rar[QUOTE = szengen; 3843440] xx ? xx ? 2 pawls are to have a mirror height
    83 1 33 4 -ORYG.
    83 Q 33 1-SUPER CONDOR ......... [/ QUOTE] ...........
  8. #1582
    Dec 2018
    New database update for dolphin. Cuts va2eh2 correct.
  9. #1583
    auto techniek's Avatar
    Mar 2017
    Can someone decode this Ford FO21 key pls?
    can t decode with condor.
  10. #1584
    Dec 2018
    Its not a good picture.... 6 cuts, 4 depths. Count first from head.... uncut =1, deepest cut down to the edge=4.... 2/3 in the middle.
  11. #1585
    Aug 2012
    outerspace
    Need better pictures
  12. #1586
    sdnatlst's Avatar
    Aug 2011
    England
    my mini condor struggles with HU101 emegergency blades that come from smart remotes, as it only takes 1 pass over hu101 and some of the emergency blades are poor metal
    can i tell my machine to take more than 1 pass over hu101, it takes 2 over all other blades for some reason, just not hu101
    Tools owned -
  13. #1587
    Feb 2014
    Recently got 3 broken cutters on HU64 on Condor MINI. It just wants to cut them in one length and depth with maximum movement speed. Don't know why. Even when setting are to move slowly and to do it at three depths it seems like it doesn't listen to it's settings. For other keys there's no such problem. Last night updated to last version but there was no info on fixing any issues with HU64 there...
    Any one knows how to save the next cutter from braking?
  14. #1588
    Autronico's Avatar
    Jan 2017
    ITALY
    Hi, has anyone had the opportunity to decode and mill a HU149 key of a 2017 W Touran?
  15. #1589
    Quote Originally Posted by Autronico View Post
    That looks like HU162T?
  16. #1590
    Apr 2016
    uk
    Quote Originally Posted by autoTkey View Post
    There is a video on YouTube with a Russian (probably) decoding and cutting these but as hu162..
