Condor XC-mini firmware 6.1.1 is available (KM02 and KM03).
Does anybody else have a problem with the new HU162 - 8 Cut for Golf 7? I think it's on clamp B and the key doesn't grip properly. Why don't they change the clamp to the other side just as they did with the 9 and 10 cut? It would hold better.
Hello, just got a Condor XC-MINI. When calibrating the tool instruction says the drill protrusion should me less then 2cm but when I set it to less the tool will not go down enough and calibration fails. Should it be more than 2cm not less???
Thaks.
Best Regards, Roth.
Latest version for XCMINI KM02 is 6.1.1.
Yes, I know that. I watch all the videos on line and following the manual. It says insert the cutter all the way up so the distance A is less than 2cm. When I do that the calibration will not complete because the cutter does not touch the clamp.
Also, sometimes calibration will not start. The machine will be stuck on the 2 spinning circles for ever. Then you have to turn power off/on and try again. That happens randomly, clamp 1 or 2. I'll update the machine and try again.
OK, was able to calibrate the machine after a few tries. I think it is good to go now.
I try to cut the BMW HU92 key. Cuts OK, key opens the door but the cutter goes to deep and the uncut area is very thin. Is there a way of adjusting this?
Best Regards, Roth.
hello in some faulty cases, I am reducing the depth of cut. + - setting
XC Mini Plus - app see and connect with machine, but app cant download database. "no file on server".
Faraday (13th July, 2020)
