jodge (18th July, 2020)
6.1.3
Hon66 doesn't work and cuts all along blade (6.0.3 works perefect)
Toy43 ten cut doesnt work. Key only turns in one direction. Cutting procedure was changed and now cuts wrong and takes longer. (6.0.3 works perfect)
does condor support HU162 9-3-3 decode? the side cuts? or do we have to enter side cuts manually
Tools owned -
condor decode ok hu162 9-3-3 I doit yestrday
Weasel3 (23rd July, 2020)
why all of you people who has an issue not complain directly to xhorse ?
not even send feedback to your seller to forward it to xhorse ?
that's easy
They don't care our problems. No matter the type of the tool nor the chanel of the complain. There is no real working bugfix system with feedback. Thats why. So this threads our whining places
Just a few things from the last 3 years:
condor
YM15 key tip cutting
GT15 key tip cutting
VVDi2 Mercedes ID33 trasponder error
feel free to read this topic or the vvdi2
Interesting
Yet to install this new kit. My issue was always the opposite end of the key with the A5.
Shave off bit before cut 1.
I'm sure our issues are related and u guys r looking in wrong location.
But could/(hay probably) be wrong, as yet to play with my new Xhorse cutter. Will give feedback as have few merc locks around
Solidarity with Ukraine
anyway ..... DK is not a proper place to post issue
Nobody will check hundreds of VVDi2 topic pages to find out single issue / your issue
I am also not able to focus on every single topic , especially if more info is require
you have complain form or APP - feedback and suggestions) to send information to them
jodge (27th July, 2020)
With all my respect you are doing a great job. I know the ticket stuff is your work but without feedback it's just a duck tape on a space shuttle wing, from far away it's looks like a working solution
If you almost never get answers for your problems and almost never get solutions you starting whining. They are an "old" company they are already made a lot of money. It's time to starting a working customer supoort.
to be fair xhorse has to shift tho every beginner moan
some issues are learner moans - even experts getting use to the kit.
Saying that XP-007 compared to XP-002
XC-002 is a FAR BETTER machine at 1st looks
Guess you Chinese clone Italian kit better (Matrix) than design your own. Is the 'C' in XC for clone
We shall see but the play on my XP-007 is bloody terrible,
Hoping something i missed n can adjust. But initial impression is XC is better machine for laser
The conductivity, of the key to probe is very important.
If the probe detects key, and warns about blade width.
Bends or even snaps.
This all preventable, by scraping the key edge, with something like a file, knife, etc.
Even a blade, that works one sided better, can be caused by bad conductivity.
The sx9, and some other Keys that Comes with a yellow collor coating, must be scraped.
A full charges battery, or charger attached, can improve the conductivity probing. Instead of blaming software.
Be aware off this.
Load up, a good picture of the bad cut key,
Measure it with caliper, confirm manualy the decoding,
To pinpoint the issues.
Also, the smal screw, needs to be used,
Not very tight, but pressing down, to prevent blade from turning when you clamp IT.
That could make a blade, smaller in width,
Depending, it being a right OR left blade.
This might differ sligtly.
PremierD (11th August, 2020)
6.1.5 is out for xc-mini
add plastic and aluminum key cutting
add x horse app and instacode live bluetooth setting in menu
add hyundai and daihatsu key data
fix some key cut clamp selections
fix bmw motorcycle key cut profile
fix hu101 cutting isssue
fix hu162t cutting issue
rm23 (24th August, 2020)
