I am now having issues with Dolphin cutting HON77 keys. Have three customers waitingThese were working fine earlier this month.
There is some material not removed from the start of the track. Anyone having the same issue?
Did you complain to support?
In the Xhorse APP?
Yeah, yesterday, but I am in a different timezone and didn´t got a reply until today. Talking about the usual stuff, updating the firmware (already 1.5.1), doing universal key duplication (I am cutting from code, cannot do it) and so.
I think it might be related to the latest V73 database, because it was working earlier this month. Do you know any easy way to roll the DB back?
Tried again today with V74 database but still no luck.
Can somebody confirm that is corect code, decode by eye. It is va6 from ds3
657668
Va6 renault by code full working.
When you say va2, what car you talk about.?
Envoyé de mon LYA-L29 en utilisant Tapatalk
Manual machine - No problem
Automatic - need to make a small spacer about 0,7mm-0,8mm - from sheet metal - About the same thickness of a lot vehicles.
So you can make it from an old door of a car, from the junkyard.
Same problem with Toyota one side cut. Same solution with this.
I have not used the Dolphin with this spacer, but other automatic machine works fine.
I guess I can test the Dolph also, one day.
This is issue since day one with all Condors... It won't be fixed.
Weasel3 has shared the best solution for it.
I think Miracle machines have the same problem with VA2 emergency too.
Made a emergecy blade hu64 with the dolphin for a mercedes sl 2005. key works on doorlock but not on trunk. How can that be? Customers key works on both. It was an cgdi emergency blade.
hello, this happened to me too, the restraint part of the key was a little behind.
Alpaholic (21st May, 2021)
